When I open my dxf file on my machine it opens it like nothing is grouped together and like there are different layers. Is there some settings I need to check or what is going on?
Hi @Anonymous,
Welcome to the Autodesk Community and the ArtCAM Forum!
What version and build of ArtCAM Express are you working in? To confirm this, select the Help > About ArtCAM Express menu option in your ArtCAM software. For example, ArtCAM Express 2015 R2.SP3 (64-bit build 860).
When exporting vectors in DXF format from ArtCAM Express 2015 R2, grouped vectors are not preserved. The Development team are already aware of this limitation, and there is an existing change request to preserve vector grouping when exporting in DXF format. Therefore, I have added your comments to the existing change request task, and I'll be sure to keep you updated on the Development team's response.
That said, please note that ArtCAM Express has been discontinued since 1st August 2016. You might find this article in the Autodesk Knowledge Network article useful.
Thanks in advance for your time and understanding.
Kind regards,
64 bit build 813. my brother uses artcam and he can export to dxf and I can open it with no problem. he is using artcam express 2015 64 bit build 261. Can you just send me his build that way I know everything will work and I can get some work done because right now its pretty much useless to me. I know its not your fault just frustrating. Thanks.
Hi @Anonymous,
@Anonymous wrote:
64 bit build 813.
You aren't using the latest build of ArtCAM Express 2015 R2 available to you.
Please use the following steps to download and install ArtCAM Express 2015 R2.SP3 (build 860):
That specific build number is associated with the initial customer release of ArtCAM Express 2015 (Download Only), and you have a licence for ArtCAM Express 2015 R2 (Boxed). The nearest build available to you is ArtCAM Express 2015 (build 244), which is the initial customer release of ArtCAM Express 2015 (Boxed).
Please use the following steps to download and install ArtCAM Express 2015 (build 244):
If you have any further questions, please do not hesitate to ask.
Thanks in advance for your time and cooperation.
Kind regards,
