When I hover over a button, I get a rectangle that pops up to tell me what the tool is.
My problem is that this does not happen if that same button is in a custom toolbar. The only setting I've found that may correspond to that is the Screen Tips, which I do have enabled. Is that what I should be looking for, or is there another setting?
In Artcam 2015, all the buttons showed up with the information rectangle, and I'd like the same behavior in 2017 Premium too.
Solved by dillon.moulder. Go to Solution.
Hi @Anonymous,
Many thanks for reporting this issue with ScreenTips missing from custom toolbars. I can reproduce this issue in Autodesk ArtCAM Premium 2017 Service Pack 3 (build 238), so I'll report it to the Development team for further investigation. I'll be sure to keep you updated on their response.
Thanks in advance for your patience and understanding.
Kind regards,
Hi @Anonymous,
A fix for this issue has been implemented by the Development team, and this will be included as part of a future software update. I'll be sure to let you know when this is available to download.
Thanks in advance for your understanding and patience.
Kind regards,
Hi @Anonymous,
The fix for your reported issue is included as part of the Autodesk ArtCAM 2018.1 Update. Please install it, as directed here.
If you have any further questions, please do not hesitate to ask. Otherwise, please be so kind as to accept my response as a solution. Thanks in advance for your time and cooperation.
Kind regards,
