ArtCAM Forum
Welcome to Autodesk’s ArtCAM Forums. Share your knowledge, ask questions, and explore popular ArtCAM topics.
Eding cnc post processor for ArtCam
5 REPLIES 5
1290 Views, 5 Replies
Hello
i like to now if artcam has Eding cnc post processor, does anyone knows something about this?
5 REPLIES 5
shirish.bansude
in reply to: 2071507
Hi @2071507,
Welcome to the Autodesk Community and the ArtCAM Forum.
2071507 wrote:
I like to know if artcam has Eding cnc post processor, does anyone knows something about this?
I have checked the full list of post processors included in the Autodesk ArtCAM 2017 product range, as well as testing them, and I cannot find an existing post processor compatible with the Eding CNC machine.
If you require a custom post processor for use in an Autodesk ArtCAM 2017 product, it will be necessary for you to create and submit a case from your Autodesk Account. When submitting your case, please provide us with an NC code sample which has worked successfully on your machine, as that will assist us in creating a compatible post processor.
Thanks for your time and cooperation.
Kind regards,
Shirish.B
Gary.B
in reply to: shirish.bansude
Eding uses the emc/Linux control
there is a Linux inch and mm post processor availble in ArtCam
You can also use a generic g-gode fanuc post p or the  mach3/4 post with the Eding.
note in some cases you may need to adjust the post.
Gary
Carveco Distributor USA; Legacy ArtCAM Training & Support
Beckwith Decor Products
jennifer.dunn
in reply to: Gary.B
there is a Linux inch and mm post processor available in ArtCam
Thanks for sharing that information, @Gary.B. Really good to know!
Cheers,
Jennifer Dunn
mmarands321
in reply to: jennifer.dunn
 Hello my friends this post process for woodpecker engraving from different cam program  Router 8
i need post process for artcam , i hope i can find help thanks
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; WOODPECKER HPGL 3D
;; PP 18/02/1996
;; PP 24/07/1997
[Information]
ReleaseDate=1997/07/24
CNC=WOODPECKER
MachineTool=WOODPECKER HPGL 3D
MachineManufacturer=WOODPECKER
[Principal]
NomMachine=WoodPecker 3D
TypeMachine=2
FamilleMachine=112
WhoAmI=WOODPECKER
TyDri=3
TyUs=0
DLL="MACWDPC.DLL"
DIMMACHINE=-0.105,-0.148,-0.50,+0.105,+0.148,+0.50
STDPOINT=0.0,0.0,0.0,3
TYPEAXE=1
PANELAXE=0
ACCURATE=0.00001
PORT=0
PORTDESCR=
VTA=1
XyzIni=0.000000,0.000000,0.010000
XyzUp=0.000000,0.000000,0.010000
XyzTch=0.000000,0.000000,0.010000
XyzVtm=40000.0,40000.0,-40000.0
IjkVtm=40000.0,40000.0,-40000.0
Zd=0.000000
Zf=-0.050000
Zp=0.001000
Zg=0.000200
TyZp=0
Zi=0.001500
Nmin=1
Nmax=1
WithCtrlZlevel=1
Fwith=0
Frmin=1.0
Frmax=10.0
Ftomac=16.66666
Tsz0=
Tsz1=
NszEnd=;\r\n
; Total
HeadTotNb = 1
HeadTotSz0 = ";IN;PU;ZZ1;PA"
HeadTotPcrNb = 2
HeadTotPcrSz0 = "SFf0,f2;VSf3,f3;PU"
HeadTotPcrSz1 = "SPt"
EndTotNb = 1
EndTotSz0 = "SP"
; mode calque par calque
HeadLayNb = 1
HeadLaySz0 = ";IN;PU;ZZ1;PA;"
HeadLayPcrNb = 2
HeadLayPcrSz0 = "SFf0,f2;VSf3,f3;PU"
HeadLayPcrSz1 = "SPt"
EndLayNb = 1
EndLaySz0 = "SP"
; pcr by pcr
HeadPcrNb=3
HeadPcrSz0=;IN;PU;ZZ1;PA
HeadPcrSz1=SFf0,f2;VSf3,f3
HeadPcrSz2=SPt
EndPcrNb=1
EndPcrSz0=SP
Mami0=PAx,y,z
Mami1=PUx,y,z
Mami2=PUx,y,z
Mami3=PUx,y,z
Mami4=PAx,y,z
Mami5=PAx,y,z
Mami6=PAx,y,z
Mami7=PAx,y,z
Mami10=PAx,y,z
Mami11=PAx,y,z
Mami12=PAx,y,z
Mami13=PAx,y,z
Mami16=
Mami18=PD
Opt1=0
Mami21=PUx,y,z
Mami22=PUx,y,z
Mami23=PAx,y,z
Mami24=PAx,y,z
Hi @tareq.alsaeed1993,
What version and build of Autodesk ArtCAM are you working in? To confirm this, select the Help > About Autodesk ArtCAM menu option in your ArtCAM software. For example, Autodesk ArtCAM Standard 2018 (Version: 2018.2.0 Build: 2017-12-07-1854-b336f4842).
Have you tried selecting the Mach3_4 (inch)(*.TAP) or Mach3_4(MM)(*.TAP) option from the Save Toolpaths dialog's Machine file format list when saving your toolpaths? Please confirm.
If you require assistance with a post processor for your Woodpecker CNC machine, please create and submit a case from your Autodesk Account.
A customer with an active subscription for Autodesk ArtCAM Standard or Autodesk ArtCAM Premium is entitled to request assistance with post processors from Autodesk Support. An initial assessment on post processor development undertaken by a Technical Consultant does not usually incur a charge. When the Technical Consultant has assessed the amount of work involved with the requested post processor development, they will advise the customer as to whether any additional charges will be incurred. It is important for the customer to supply Autodesk Support with all of the information and supporting files they request during this process.
If you have any further questions, please do not hesitate to ask. Thanks in advance for your time and cooperation.
Kind regards,
