Dear Autodesk,
Please take next repetable crash test and video.
Files will be send by we transfer to Adam Rogalinski, Adam Barycki & Karl Kalamägi.
Solved by dillon.moulder. Go to Solution.
Hi @tomas.sliauteris & @karl,
The Development team have implemented a fix for this issue, and it will be included as part of a future software update for the ArtCAM 2017 product range. At this moment in time, I do not have a scheduled release date for this update, but I'll be sure to let you know as and when I do.
Thanks again for your understanding and patience.
Kind regards,
Ok seeing as to how just about everything I do on this machine causes a crash with ArtCAM and maybe its the version of Windows 10 Im using. Would this be beneficial for me to downgrade to Windows 7?
Hi @sonicpaint92,
The Autodesk ArtCAM 2017 product range is supported on the Windows 10 operating system, as documented in the software's system requirements. Therefore, I do not recommend that you downgrade your computer's operating system to Windows 7.
Please allow the Development team time to analyse the ArtCAM MiniDump files (*.dmp) you've submitted to Autodesk Support when you've encountered a crash while working in Autodesk ArtCAM Standard 2017. Thanks in advance for your patience and understanding.
Kind regards,
Hi @sonicpaint92,
have the developers had any luck
All of your supplied ArtCAM MiniDump files (Dump-20161220-173245-2017-238-64.dmp, Dump-20161218-115038-2017-238-64.dmp, Dump-20161210-190949-2017-199-64.dmp and Dump-20161215-161843-2017-238-64.dmp) indicate that the crashes in Autodesk ArtCAM Standard 2017 result from your NVIDIA display driver (nvoglv64.dll).
Therefore, please complete the following steps on your computer:
Please let me know if updating your NVIDIA graphics card's display driver resolves your issue. When doing so, please confirm what model of NVIDIA graphics card you have installed on your computer, and what display driver version you have installed. To do so, you can run the System Information Finder tool on your computer, and attach the three output files (*.txt) when replying to this post.
Thanks in advance for your time and cooperation.
Kind regards,
Dillon, I already have the latest driver for the graphics card and the settings in ArtCAM to what you suggested. Im attaching the 3 files hopefully these will shed some light. Thank you again for the support.
Hi @sonicpaint92,
I already have the latest driver for the graphics card and the settings in ArtCAM to what you suggested. I'm attaching the 3 files hopefully these will shed some light. Thank you again for the support.
Many thanks for supplying your three System Information Finder output files. Your computer has an NVIDIA GeForce GTX 950M graphics card and integrated Intel HD Graphics 530. In order to confirm which of them Autodesk ArtCAM Standard 2017 Service Pack 3 (build 238) is currently utilizing, please complete the following steps:
Please attach the Information.txt file when replying to this post. Thanks in advance for your time and cooperation.
Kind regards,
Hi @sonicpaint92,
attached is the file.
Many thanks for supplying your information.txt file.
Looking at the file, Autodesk ArtCAM Standard 2017 Service Pack 3 (build 238) is definitely utilizing the NVIDIA GeForce GTX 950M graphics card installed on your ASUS X550VX laptop and you do have the latest NVIDIA display driver installed (376.33).
Have you already tried disabling the Intel HD Graphics 530 on your ASUS X550VX laptop? Please confirm.
Kind regards,
I tried to disable it but the screen got crazy on me and I re-enabled it. Now last night I right clicked on ArtCAM and selected run with graphics processor and selected the nvidia card and it went well doing it that way.
Hi @sonicpaint92,
The reason I asked about disabling the integrated Intel HD Graphics 530 is that there could be the potential for it to interfere with the NVIDIA GeForce GTX 950M card during your Autodesk ArtCAM 2017 session.
Ensuring that Autodesk ArtCAM Standard 2017 is always using the NVIDIA GeForce GTX 950M card should avoid the issues you've reported. Therefore, when starting Autodesk ArtCAM Standard 2017 Service Pack 3 (build 238), please right-click the Autodesk ArtCAM 2017 shortcut and select the Run with graphics processor > High-performance NVIDIA processor (default) option to force it to run with the NVIDIA GPU instead of the Intel GPU.
If you should encounter any further crashes when starting Autodesk ArtCAM Standard 2017 Service Pack 3 (build 238) using this method, please let us know.
Kind regards,
I will keep you posted and thanks again for everything you and your team have done to correct this issue. Danny Quinn
No problem at all, @sonicpaint92. Hopefully, you won't encounter further crashes when working in Autodesk ArtCAM Standard 2017, but we'll be ready to assist if you do.
Kind regards,
tomas.sliauteris wrote:Please take next repeatable crash test and video.
The fix for your reported issue is included in the fourth service pack release for the Autodesk ArtCAM 2017 product range. Please download and install it, and then be kind enough to accept this post as a solution.
Kind regards,
