Does anyone have a font for a class ring like the one I've attached. Specifically I'm looking for where the numbers are squared off like attached vs a rounded number 9 for example.
TIA
Solved by shirish.bansude. Go to Solution.
Hi @zachary,
I was able to find a similar square shaped True Type font here.
I downloaded the SF Square Head Regular font and copied it to C:\Windows\Fonts on my computer, so that that it would be available to select from the Text Tool's Font list.
Please refer to the screenshot below, which shows the result of using this font:
I hope that this helps.
I recommend that you search the internet for similarly-shaped True Type fonts, and then copy any that you've downloaded to C:\Windows\Fonts on your computer so that they are available for use in your Autodesk ArtCAM Premium 2017 software.
If the provided information is helpful to you, please be kind enough to click the Accept As Solution button below. Alternatively, reply back to me and I will be happy to assist you further.
Thanks for your time and cooperation.
Kind regards,
