In preparation for delivering the first software update for the ArtCAM 2017 product range through the Autodesk Desktop App, the ArtCAM Development team have released a hotfix; this implements a minor ArtCAM registry fix.
To install the hotfix, please follow these instructions:
When the first software update for ArtCAM 2017 is available to customers, this will be announced here on the Autodesk Community ArtCAM Forum.
Thanks in advance for your time and cooperation.
Kind regards,
That actually fixed the App for my other Autodesk products 🙂
When I started up the App even though I am logged in it said I did not have any products registered - now it shows them all except for AC2017. AC still shows up in my Web login though.
Provided you've installed the hotfix for ArtCAM 2017, the first service pack for the Autodesk ArtCAM 2017 product range (Free, Standard & Premium) is now available to download through the Autodesk Desktop App:
Details of the fixes and enhancements included in the first service pack for ArtCAM 2017 are listed here.
Thank you again for your patience and understanding.
Kind regards,
Hi @tajs,
@tajs wrote:
A sincere thank you to all involved in getting this first hotfix and service pack out, it is very much appreciated.
Many thanks for your kind words of support.
Kind regards,
Dillon,
does the current download for 2017.199 include this hotfix or is it still required to be run
thanks
Gary
Hi @Gary.B,
The hotfix modifies registry entries associated with Autodesk ArtCAM 2017 in order to facilitate for the Autodesk Desktop App delivering software updates as expected. I'm not entirely sure if the second service pack for the Autodesk ArtCAM 2017 product range includes the same registry modification as in the hotfix, so I will have to carry out some testing in order to confirm this. I'll be sure to let you know my results. In the meantime, I recommend that customers install the hotfix prior to installing the second service pack for Autodesk ArtCAM 2017 product range.
Thanks in advance for your patience and understanding.
Kind regards,
Hello,I downloaded Artcam 2017 but I'm looking for Jewelsmith .How do I get the download link?
Hi @nasr,
Welcome to the Autodesk Community and the new ArtCAM Forum! Many thanks for joining us from the original ArtCAM Forum.
@nasr wrote:
I downloaded Artcam 2017 but I'm looking for Jewelsmith. How do I get the download link?
What version of Autodesk ArtCAM 2017 have you downloaded (Free, Standard or Premium), and from where? Please confirm.
ArtCAM JewelSmith is not part of the Autodesk ArtCAM 2017 product range, and has been discontinued; this is confirmed here in the Autodesk Knowledge Network.
All of the functionality associated with ArtCAM JewelSmith 2015 R2 is included in Autodesk ArtCAM Premium 2017, with the exception of KeyShot and POV-Ray support; KeyShot is not bundled with the free version of Autodesk ArtCAM 2017, Autodesk ArtCAM Standard 2017 or Autodesk ArtCAM Premium 2017. Therefore, Autodesk ArtCAM Premium 2017 can be used for the design and manufacture of jewellery in exactly the same way as ArtCAM JewelSmith 2015 R2. You can compare the different products in the Autodesk ArtCAM 2017 product range here.
If you have any further questions, please do not hesitate to ask. Thanks in advance for your time and cooperation.
Kind regards,
Hi Dillon,
Tried the hotfix on 2 pcs and ArtCAM doesn't appear on either of them in the app even though my Fusions 360 does.
Could it be because I don't have my ArtCAM installed to the default location?
Alex.
Hi @alex2027,
Welcome to the Autodesk Community and the ArtCAM Forum!
alex2027 wrote:Tried the hotfix on 2 pcs and ArtCAM doesn't appear on either of them in the app even though my Fusions 360 does.
What version and build of Autodesk ArtCAM 2017 did you have installed prior to installing the hotfix? To confirm what version and build you currently have installed, select the Help > About Autodesk ArtCAM menu option in your ArtCAM software. For example, Autodesk ArtCAM Premium 2017 Service Pack 2 (build 199).
After you installed the hotfix, were you prompted to restart your computer? If so, have you restarted your computer yet? Please confirm.
What is the install path for the Autodesk ArtCAM 2017 software on your computer? Please confirm.
Kind regards,
It's 2017 premium .199 on one pc and .199 and .266 on another.
Both restarted after the hotfix.
The first pc .199 is in C:\Software\ArtCAM 2017
On the second pc .199 is in C:\Software\ArtCAM 2017
and .266 is in C:\Software\ArtCAM 2017 266
Alex
Hi @alex2027,
You should not have to install the hotfix on any computer on which you have Autodesk ArtCAM Premium 2017 Service Pack 2 (build 199) or later installed, because the functionality of the hotfix was included in the second service pack release for the Autodesk ArtCAM 2017 product range.
None of the four service packs for the Autodesk ArtCAM 2017 product range have an associated build number of 266. The third service pack release is build 238, while the fourth service pack release is build 268.
Please explain why you've chosen to attempt to install Autodesk ArtCAM Premium 2017 twice on the same computer in two separate locations.
I will need to discuss the potential for your chosen installation methods to interfere with the Autodesk Desktop App with the Development team when I return to the office tomorrow; it is now 23:49 in the United Kingdom.
Thanks again for your time and cooperation.
Kind regards,
