Solved by dillon.moulder. Go to Solution.
Solved by bgoodman4. Go to Solution.
Solved by shirish.bansude. Go to Solution.
Solved by tajs. Go to Solution.
Hi @bgoodman4,
@bgoodman4 wrote:
now they are too small, Guess I need to use larger images to start. Strange that if you click on the links to the attached images in my e-mail above the images are nice and big. The images in this e-mail are too small to see the detail properly,,,,,,and its all about the detail.
When posting, please confirm whether you're using these steps to insert your images into your post:
Thanks in advance for your time and cooperation.
Kind regards,
Hi @tajs,
These are beautiful pieces! Many thanks for sharing them with the Autodesk Community.
Kind regards,
