ArtCAM Forum
Welcome to Autodesk’s ArtCAM Forums. Share your knowledge, ask questions, and explore popular ArtCAM topics.
3D TEXT
5 REPLIES 5
pb3d
554 Views, 5 Replies
3D TEXT
with ARTCAM you can create a 3D text with a draft angle, projected onto cylindrical surface?
5 REPLIES 5
tajs
in reply to: pb3d
Yes, the letters have a 20 degree draft.
shirish.bansude
in reply to: pb3d
Hi @pb3d,
Yes, this is possible with Autodesk ArtCAM Standard 2017 and Autodesk ArtCAM Premium 2017.
Please refer to the screencast shown below:
If you are planning to work exclusively with rotary models, I recommend that you use Autodesk ArtCAM Premium 2017; this has more functionality for rotary models than in Autodesk ArtCAM Standard 2017
You can find a detailed feature comparison between the products included in the Autodesk ArtCAM 2017 range here.
Thanks for your time and cooperation. If the provided information is helpful to you, please be kind enough to click the Accept As Solution button. Alternatively, Reply back to me and I will be happy to assist you further.
Kind regards,
Shirish.B
pb3d
in reply to: shirish.bansude
Thanks ..... is what I need ...
my 3d model is created with Autodesk Inventor, you can import it into artcam?
dillon.moulder
in reply to: pb3d
Hi @pb3d,
The process of importing files originating from Autodesk Inventor into Autodesk ArtCAM has previously been discussed here.
If you have any further questions, please do not hesitate to ask.
Kind regards,
shirish.bansude
in reply to: pb3d
Hi @pb3d,
I'm glad to hear from you. Thank you for the confirmation.
Please be kind enough to click the Accept As Solution button to my earlier response, so that the information provided can benefit other users with the same issue.
Kind regards,
Shirish.B
