I have recently encountered an issue with ArtCam's 3D Machining wizard. When I select my assembly and click the wizard's button, the wizard does not appear. Is there a way to revert my settings back?
Hi @Anonymous,
Welcome to the Autodesk Community and the ArtCAM Forum!
I am able to use the 3D Machining Wizard by selecting an assembly in Autodesk ArtCAM Premium 2017 Service Pack 6 (build 273).
What version and build of Autodesk ArtCAM are you working in? To confirm this, select the Help > About Autodesk ArtCAM menu option in your ArtCAM software. For example, Autodesk ArtCAM Premium 2017 Service Pack 6 (build 273).
If you have not done so already, please install the sixth service pack release for the Autodesk ArtCAM 2017 product range.
If your reported issue persists in Autodesk ArtCAM Premium 2017 Service Pack 6 (build 273), please follow these steps:
Please confirm whether these steps have resolved your reported issue.
If the provided information is helpful to you, please be kind to enough to click the Accept As Solution button. Alternatively, Reply back to me and I will be happy to assist you further.
Thanks for your time and cooperation.
Kind regards,
Hi @Anonymous,
Further to @prashant.gurav's instructions, please use Autodesk Screencast to create and share a screencast demonstrating the issue that you're describing. You can find instructions on how to embed a screencast when posting to the Autodesk Community forums here.
Thanks in advance for your time and cooperation.
Kind regards,
