Rendering this image using cpu mode actually took 12 hours to render.
66175545
Message 1 of 10
66175545
Replies (9)
Message 2 of 10
lee_griggs
Camera (AA): 10) seems very high for such a simple scene. I would have thought 5 would be sufficient.
How many light samples are you using?
Are there any render warnings in the log file?
How long does GPU take, btw?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 10
66175545
Attached is the rendered output with the camera sampled at 5. The light sampling only gives 3 for domelight, and only 1 for the other lights. the logs do not report errors.01.jpg
Message 4 of 10
lee_griggs
How long does it take on GPU with OIDN denoising (Camera (AA): 5)?
Lee Griggs
AUTODESK
Message 5 of 10
66175545
Message 6 of 10
wernienst
It's hard to tell why rendering is taking so much time without knowledge of scene illumination and materials. Obviously the shield's material has a subsurface shading component. Try reducing SSS samples.
In this simple scene I've set an environment (HDRI) and a spot light. The shield insets have a displacement map assigned. The greenish material has a transmission weight of 0.2 and a SSS weight of 0.8.
Rendering times on my (average) computer with Oidn Denoiser applied are: CPU (Camera AA = 4)  3min 23 sec, GPU (Camera AA =8) 56 sec.
Message 7 of 10
wernienst
Ah, I forgot to mention that I'm using 3dsMax 2024 and MAXtoA 5.7.3.0
Message 8 of 10
thiago.ize
You have AA_max of 40 and adaptive threshold at 0.01: that's why it's taking so long. If you turn off adaptive sampling or raise the adaptive threshold (maybe 0.05?) the render should get much faster. It will of course be noiser, but as @wernienst said you can add the OIDN denoiser to remove small amounts of noise.
Message 9 of 10
66175545
Okay, thank you very much for your careful answers. I will continue to research and learn.
Message 10 of 10
66175545
Thank you very much for your help.
