Question about the render depth setting when rendering a scene with hair in it.
66175545
66175545
Can you please tell me, when rendering a scene with hairs in it, does the render setting, render depth increase TRANSMISSION help to render the hairs? Picture 1 is my rendering, picture 2 is the reference picture effect.01.jpg02.jpg
lee_griggs
You should either increase specular_ray_depth or standard_hair.extra depth.
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_core_ac_standard_hair_html
Lee Griggs
Arnold rendering specialist
AUTODESK
Ok, thank you for your careful explanation, please tell me if the value of the position of the screenshot is turned up? I found the effect is not obvious after testing.04.jpg
lee_griggs
If this is with GPU, you will need to update your plugin.
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_user_guide_ac_wn_732_gpu_hair_html
Lee Griggs
AUTODESK
Thank you very much for your guidance, but my plugin is 7.3.2, which is the latest.01.jpg
lee_griggs
It's working for me here. Maybe you could try it with a simple scene to test its working or upload it so that we can test it.
Lee Griggs
AUTODESK
Ok, thank you very much for your guidance, I'm uploading the project for help, if you have time please help to look at my project as I'm genuinely trying to figure out how to optimise it, thanks.
