Problem with Arnold render
Introduced on the CPU in Maya 2018, Maya 2020 gives such a result.
Updated the render, it did not help.
At the same time, rendering in 3D Max works correctly.
What could be the problem?
  • CPU
ramon.montoya
Can you generate a log (info level) when the render fails like that? (see https://docs.arnoldrenderer.com/display/A5AFMUG/Log )
Stephen.Blair
And is this with any scene? Or just a certain scene?
If you render to disk, is that image ok?
// Stephen Blair
// Arnold Renderer Support
