Arnold GPU Forum
General discussions about GPU rendering with Arnold.
MAXtoA 5.6.6.2 GPU rendering does not work.
6 REPLIES 6
www_imdhkim
318 Views, 6 Replies
Today I upgraded nvidia studio 551.23 and MAXtoA 5.6.6.2 and another problem occurred with the GPU rendering.
Last time, I updated nvidia studio 546.33 and MAXtoA 5.6.6.0 and failed to use GPU rendering.
I was able to update and use MAXtoA 5.6.6.1, but today I upgraded nvidia studio 551.23 and MAXtoA 5.6.2, and another problem occurred with GPU rendering.
Now I'm performing the same update to both the laptop and desktop I use for work, and the following message was displayed.
(Refer to graphic card information in the attached image)
[Arnold]: 00:00:00 3857MB ERROR | [gpu] CUDA call failed : (700) an illegal memory access was encountered
[Arnold]: 00:00:00 3857MB ERROR | [gpu] GPU context creation failed : an illegal memory access was encountered
I updated nvidia studio 551.23, and there was also a problem with GPU rendering in VRED 2024.2. Is it possible there is a problem with the Autodesk products and graphics card drives?
Personally, I don’t think that the problem lies with the optix.
Do you have any possible solutions for this problem excluding the graphics card or MAXtoA version downgrading?
6 REPLIES 6
rsparwasser
in reply to: www_imdhkim
Exactly the same here, it is possible to render a certain amount of images after that we get the same error message. Like in 5.6.6.1 output is black. If switch to CPU, the error message is the same, deleting all imagers has no affect.
This posting should be moved to ARNOL FOR 3DSMAX, assuming it’s more a MtoA problem.
Rolling back to 5.6.5.2 fixed it.
kindly
Have the same issue in Maya 2024.2 with the latest MtoA 5.3.5.2, Installing Nvidia driver 546.33 will fix this.
sbcDK388
Thank you for your replies, everyone.
I am using 3ds Max 2024.2.1 with an updated MAXtoA 5.6.6.3 (Arnold 7.2.5.2).
The Nvidia Studio is version 551.61.
Many of the errors with the current GPU seem to have been improved.
(The optix issue seems to have improved.)
However, when using the Global Light Sampling, CUDA call failed: The (700) error keeps appearing.
(I tested the Global Light Sampling value from stages 1 to 16, and kept receiving (700).)
For the Rendering Speed Up, it looks like that it may need to be updated continuously.
sbcDK388
This time, I updated the 3ds Max 2024.2 to MAXtoA 5.6.6.4 (Arnold 7.2.5.3) and updated Nvidia Studio to Version 551.86.
This update has solved the “CUDE call failed: (700)” error that comes up when you use Global Light Sampling for GPU rendering.
(It looks like the optix problem is being improved.)
https://youtu.be/L_Khx2CJoDI
The GPU renderer has been working very well for quickly checking/fixing the light settings. 🙂
However, there seems to be a problem if you use Adaptive Sampling for GPU rendering.!!!
CiroCardoso3v
in reply to: sbcDK388
Adaptive sampling seems to be off in your case
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
sbcDK388
in reply to: CiroCardoso3v
Thank you for replying.
Yes, the check was disabled for Adaptive sampling in the video above.
When I checked the Adaptive sampling and ran the rendering for the video above in GPU Mode, the rendering didn’t start.
(3ds Max 2024.2 to MAXtoA 5.6.6.4 (Arnold 7.2.5.3))
However, this time in 3ds Max 2025 with MAXtoA 5.7.1.0 (Arnold 7.3.1.0), there were no issues with rendering and it started normally...:)
