Arnold GPU Forum
General discussions about GPU rendering with Arnold.
How to fix crash due to Empirical SSS unsupported by GPU? (EDIT: Actually due to Transmission)
4 REPLIES 4
marcogabriel.patino
2964 Views, 4 Replies
Hello! I'm very new to Arnold and GPU rendering. I'm unsure what this means exactly. Is there an easy way to fix this?
I'm on a GTX 1050 Ti.
EDIT: I tried recreating the error with a simpler scene. It seems that it only crashes when the material has some sort of transmission or SSS? It crashed on Glass and Plastic but not Brushed Metal. I'll keep trying.
EDIT 2: It's definitely only Transmission. Tested multiple SSS scenes and they rendered fine (although very noisy).
Tags (2)
Labels (2)
4 REPLIES 4
Hi Marco, Would it be possible for you to provide an .ass file of the repro for us to test please?
Guys, do you have any update on this, or you can't reproduce the issue without that file?
thiago.ize
in reply to: matissjansons1
A lot of bugs have been fixed over the last year. Can you tell us what your nvidia driver and arnold versions are? Can you post the complete error message (copy/paste the entire error here instead of a screenshot that clips the important error details)?
[c4dtoa] 00:00:01 6138MB WARNING | [gpu] Empirical SSS unsupported on GPU, switching to randomwalk in shader /D_BlackBumpyPlastic|Arnold_Default_Material
[c4dtoa] 00:00:01 6138MB WARNING | [gpu] Empirical SSS unsupported on GPU, switching to randomwalk in shader /Camera_Paint|Arnold_Default_Material
[c4dtoa] 00:00:01 6163MB WARNING | [gpu] Empirical SSS unsupported on GPU, switching to randomwalk in shader /Metal_Screw_Black|Arnold_Default_Material
[c4dtoa] 00:00:01 6154MB WARNING | [gpu] Empirical SSS unsupported on GPU, switching to randomwalk in shader /D_BlackPlasticScratched|Arnold_Default_Material
[c4dtoa] 00:00:01 6154MB WARNING | [gpu] Empirical SSS unsupported on GPU, switching to randomwalk in shader /D_Asphalt_01|Arnold_Default_Material
[c4dtoa] 00:00:01 6154MB WARNING | [gpu] Empirical SSS unsupported on GPU, switching to randomwalk in shader /D_Trippy_BlackRed|Arnold_Default_Material
[c4dtoa] 00:00:04 6302MB ERROR | [aov] output references a non-camera node: ID
