Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
General Maps not rendering with GPU
RichJacobUK
RichJacobUK
Hi All.
I tried out GPU rendering today for first time . I'm using 3dsMax 2024 .
As far as speed goes its way faster then CPU , but I'm losing some maps when I switch to GPU rendering. Basically, in my scene I am using the 'Tiles'  map from the 'General' section of the Maps browser to create floor tiles on a plane. When I use CPU it renders perfect but with GPU it doesn't render the 'Tiles' map. Can anyone suggest an alternative or a fix please ?
Floor Rendered with CPUFloor Rendered with CPUGeneral Maps dropdownGeneral Maps dropdownGPU region render of floorGPU region render of floorMaterial overviewMaterial overview
lee_griggs
I presume you have Legacy 3ds Max Map support enabled, otherwise it wouldn't render with CPU.
It is probably not supported with GPU. You could try a native Arnold shader like cell_noise or an OSL shader instead.
Lee Griggs
Arnold rendering specialist
AUTODESK
RichJacobUK
Thanks a lot Lee.
Yes I had compatibility Mode for '3ds Max Maps Support' selected.
Thanks for the alternative suggestion 🙂
I'll give that a go.
Kind regards
RichJacobUK
Just to update. I used an OSL map plugged into the Arnold Standard Surface. Worked great. It was the OSL Simple Tiles map.
Thanks for your help Lee.
Much Appreciated
