c4d version 2024.4.1 dynamics rendering output issue.
66175545
Message 1 of 8
66175545
When I use c4d version 2024.4.1, I use dynamics in the scene, and I found a problem: i.e. I have cached all the dynamics and they are displayed correctly in the IPR, but in the final rendering the dynamics are shown incorrectly (they are not cached), how can this be solved please?01.jpg
Replies (7)
Message 2 of 8
peter_horvath
I'm not sure this is an Arnold specific issue. I see the meshes at the same (incorrect?) position in the viewport, in my IPR and Picture Viewer renders.
I have tried in Cinema 4D 2024.4.0 though. Maybe there's an update/bug in 2024.4.1, where the viewport is correct, but the final render is not.
You can try rendering the scene with another renderer (like Standard or Redshift) to check if you've got the same result in the Picture Viewer.
// Peter Horvath
// C4DtoA developer
Message 3 of 8
66175545
Thank you for your thoughtful pointers, I was testing with the default renderer and found that the results were wrong as well. Looks like I'll have to fall back to the last c4d version (2024.0).
Message 4 of 8
66175545
I'm confused, I don't know if it's a C4D issue or an Arnold issue? Please give me help or answer. The test rolled back the c4d version to 2024.4.0 after a rendering test the result is shown in the picture, the latter picture is the final rendering of the previous output also using the c4d 2024.4.0 version shows no problem (rendered output before upgrading c4d 2024.4.1).02.jpg03.jpg
Message 5 of 8
66175545
It was found that the rendered output was fine using the analogue tabs and not fine using the bullet tabs, as shown in the figure.01.jpg02.jpg
Message 6 of 8
66175545
It was found that not caching the final rendering results correctly. As shown:01.jpg
Message 7 of 8
peter_horvath
I think it's a Cinema 4D issue. I suggest you to report it to Maxon to confirm.
// Peter Horvath
// C4DtoA developer
Message 8 of 8
66175545
Okay, thank you very much.
