Arnold GPU Forum
General discussions about GPU rendering with Arnold.
Autobump in SSS using GPU doesn't work
1 REPLY 1
konstantinos_chtenelisXDG7U
219 Views, 1 Reply
It works only using CPU rendering.
Tags (1)
1 REPLY 1
Hi, full feature parity between GPU and CPU is still being worked on. This (adding support for SSS+autobump on GPU) is a known limitation tracked internally by ARNOLD-8494. When this feature is added, the release notes will mention ARNOLD-8494.
To help with prioritizing when to work on this, I've added a note to that ticket citing you need this feature.
