Arnold GPU Forum
General discussions about GPU rendering with Arnold.
Arnold 4.6.7 GPU BUG
3 REPLIES 3
RaynerR
295 Views, 3 Replies
When Arnold uses GPU rendering, there will be a bug with light exclusion, which will not illuminate the excluded object, but will leave diffuse and shadow on the object, and rendering transparent objects cannot exclude the background
CPU rendering
The following is GPU rendering:
Labels (1)
3 REPLIES 3
peter_horvath
in reply to: RaynerR
I can reproduce the problem with the shadow, but not with the transparent object. Could you please send me a scene to look at?
// Peter Horvath
// C4DtoA developer
RaynerR
in reply to: peter_horvath
Okay, this is a simple scenario I used for testing. In GPU mode, PNG with transparent channels cannot be rendered
peter_horvath
The difference you see in transmission is caused by the Transmit AOVs flag in the standard_surface shader. This flag affects the alpha of the image, and is not supported on the GPU.
// Peter Horvath
// C4DtoA developer
