Arnold General Rendering Forum
Why the model texture wont disappear
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
412 Aufrufe, 4 Antworten
I have an image and have a look. I'm trying to do some dissolve effect.
Tags (2)
Beschriftungen (2)
4 ANTWORTEN 4
Nachricht 2 von 5
lee_griggs
als Antwort auf: Anonymous
Can you provide more information about how you are doing it? What shaders/textures are you using? Are you using Transmission or Opacity or is this a particle shading effect?
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 3 von 5
Hi Lee,
I used the texures from Substance Painter with png images and export to Ai Standard Surface. After that, I used black and white images for 3 secs that make the textures gone (you can see on the left side). The black and white images I put them into Tranmission then emiter the object. The problem is Maya view is worked but Arnold doens't.
Nachricht 4 von 5
lee_griggs
Is Opaque disabled (not necessary with the latest release). Maybe Opacity would work better instead of Transmission?
Lee Griggs
AUTODESK
Nachricht 5 von 5
Hi Lee,
I did put the black and white images into Opacity and disabled Opaque and it's worked!!!! Thanks for support. :leicht_lächelndes_Gesicht:
