Hey there, it's all in the question really . . .
There is a little info say on that command, but not others ?
ie arnoldRenderview -mode "open" is listed as an option, what are the other strings that can be passed etc. Is this buried in a python file in the installation ?
Attached are more commands . . . ?
This is the only page in the manual that I can find... with some relevant information. It would be useful to exploit some of these commands without digging into the python files, ie. too much work!
https://support.solidangle.com/display/AFMUG/Arnold+RenderView+Window
Many thanks
Alan.
There is no documentation.
By default, with no -mode flag, arnoldRenderView opens the Arnold Render View and renders
If you want to open the Arnold Render View without rendering, then you add -mode "open"
Possible modes are
For the -opt flag, you must use the exact menu label text for the option.
Thanks Stephen,
I wonder is there a command to query if the Arnold renderview is open or closed ?
Thanks a lot.
A
Not that I know of. Does Maya itself have an API for finding the open windows and panels?
Hey Stephen, yes I have tried that, not reading that the Arnold RenderView window is there. Uses 'lsUI' command. Don't know if its a python thing, but pretty sure python would just read the same command. Thanks.
Ah nevermind, found it...
workspaceControl -q -vis "ArnoldRenderView";
This works for finding if the renderview is open or closed.
Thanks.
