Arnold General Rendering Forum
what is a shader in arnold
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
selvakvigneshmaya
423 Aufrufe, 4 Antworten
I'm currently getting into rendering .My sir told me there are different types of of shaders we can use within maya through arnold but i couldnt get a proper explnation of  what a shader means or do in simple wordds both from the internet and my professor .Can someone tell me what a SHADER means and what is the term rendered using arnold .Thank you.
4 ANTWORTEN 4
Nachricht 2 von 5
A shader is the underlying tech to recreate real world materials. One example is the standard surface shader. An other one would be a hair shader.
https://autodesk.github.io/standard-surface/
https://linktr.ee/cg_oglu
Nachricht 3 von 5
Thanks .That clears all about shaders .May i know what rendering means in 3d terminology
Nachricht 4 von 5
Thats the process where the computer generates the image based on the scene geometry, shaders and light.
There are different methods but the most used is raytracing.
https://youtu.be/gsZiJeaMO48
Nachricht 5 von 5
Thank you so much always a life saver .
