Arnold General Rendering Forum
We just installed Arnold MtoA 3.1.2 on our systems but we get Insufficient Memory issue on the farm
7 ANTWORTEN 7
Nachricht 1 von 8
MediaMonkSupport
690 Aufrufe, 7 Antworten
We just installed Arnold MtoA 3.1.2 on our systems but we get Insufficient Memory issues on the render farm
864MB ERROR | problem with texture: regex_error(error_stack): There was insufficient memory to determine whether the regular expression could match the specified character sequence.
I'm doing some tests and rolled back first to MtoA 3.0.0.2 our previous version and then to 3.1.1
We don't have issues with the same scene with both version only with the MtoA 3.1.2
Any idea why we are getting this error with this latest update?
Cheers
Beschriftungen (3)
7 ANTWORTEN 7
Nachricht 2 von 8
Stephen.Blair
als Antwort auf: MediaMonkSupport
Can you post a full log so I can tell when this happens? (eg during the render, during scene translation, during scene init, ...)
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 8
MediaMonkSupport
als Antwort auf: Stephen.Blair
2019-01-09 14:48:01:  0: STDOUT: 00:00:04   977MB ERROR   |   problem with texture: regex_error(error_stack): There was insufficient memory to determine whether the regular expression could match the specified character sequence.
2019-01-09 14:48:01:  0: STDOUT: 00:00:04   977MB ERROR   |   [texturesys] unspecified OIIO error (filename =  "M:/m/mediamonks_post/flip/00_pipeline/03_lookDevScenes/textures/lookdev_hdri_2k_01.tx")
Nachricht 4 von 8
Stephen.Blair
so, this is after bucket rendering started?
// Stephen Blair
Nachricht 5 von 8
MediaMonkSupport
Nachricht 6 von 8
Stephen.Blair
@Purchase MediaMonks
Is it just that one texture that causes the error?
Try removing
and the original texture too.
If you're using MayaFile, it will use the default color if the texture is missing.
If you're using aiImage, you'll need to enable Ignore Missing Texture
Also, increase the MtoA log verbosity to Info
// Stephen Blair
Nachricht 7 von 8
MediaMonkSupport
It seems the tx files is giving the error.
It is strange it does render with previous versions of Arnold.
I've opened the tx (renamed to tif) in Photoshop and it is transparent and it consists of multiple channels...
other tx files (renamed to tx) are appearing as one image, if tested a couple...
Nachricht 8 von 8
Stephen.Blair
Can you send some of those problem tx files to support@solidangle.com ?
Actually, it's not strange because there was a major update in OIIO (the image IO library that Arnold uses).
// Stephen Blair
