Arnold General Rendering Forum
Voronoi texture/shader for Arnold
10 ANTWORTEN 10
Nachricht 1 von 11
am_wilkins
1730 Aufrufe, 10 Antworten
I thought I'd make a new post regarding this, since the last I've seen are from 2011 and 2020.
https://forums.autodesk.com/t5/maya-ideas/voronoi-noise-node-and-blender-like-shader-controls/idi-p/...
https://forums.autodesk.com/t5/maya-shading-lighting-and/voronoi-cellular-noise-patterns-in-maya/td-...
Is there a reason why Arnold doesn't have a Voronoi shader/texture node?
It's definitely one of the main noise required for many different setups.
Or is there a way to create one, custom plugin etc. ?
Something similar to the texture from Blender.
all the best,
amwilkins
10 ANTWORTEN 10
Nachricht 2 von 11
thiago.ize
als Antwort auf: am_wilkins
Nachricht 3 von 11
am_wilkins
als Antwort auf: thiago.ize
Hi Thiago,
Thank you...yeah I've seen that one.
But does it produce the same results when used for something like a normal map?
Just some quick testing doesn't appear to, but maybe I'm doing something wrong.
We just get black and white values?
Result I'm hoping to see. Better faceting.
Thank you!
amwilkins
Nachricht 4 von 11
thiago.ize
You need to invert the cell_noise. Once you do that it works:
cell_noise
 name mycell
 pattern noise1
 additive 0
 amplitude .5
 scale 5 5 5
 coord_space "object"
 lacunarity 5
subtract
 name invert
 input1 1 1 1
 input2 mycell
bump2d
 name bump2d1
 bump_map invert
 bump_height 0.05
Nachricht 5 von 11
am_wilkins
Thank you Thiago, that's interesting it's needs to be inverted and also have to use Noise1 or Noise2.
Surprised the Cell Noise doesn't appear to work with the same setup.
Another question, again trying to match some behavior to Blender here and show there is some interest in more features on these nodes if required.
How would you smooth the sharp edges in Arnold?
Thanks!
amwilkins
Nachricht 6 von 11
martinkindl83
thats awesome to know,
years ago, when the new cell noise came out, i was told by developers, those two noise type wont work with normal/bump in general, something in code.
Glad i found its working, even though 4years later :leicht_lächelndes_Gesicht:
Nachricht 7 von 11
am_wilkins
Hi @thiago.ize
Just so we don't leave this thread hanging, is smoothing the voronoi / cell noise result possible with Arnold?
(like the "Smooth F1" mode in the Blender example above)
Would be great to get some confirmations and if not possible, to perhaps place a request for this feature.
All the best,
amwilkins
Nachricht 8 von 11
thiago.ize
Sorry, I have not tried creating a shader network to do this. I assume it should be possible maybe through clever use of ramps or clamps? Building all of this into a shader that ships with Arnold would of course be nice.
Nachricht 9 von 11
am_wilkins
Ok, thanks for the update!
Let me know if you get a chance, I've built some pretty cool looking stuff in Blender using this technique and would love to do the same in Arnold/port it over.
"Building all of this into a shader that ships with Arnold would of course be nice."
100% gets my vote, for what it's worth.
amwilkins
Nachricht 10 von 11
stella_ng24GWZ
I've been playing around and trying to do some testing with blender set up in maya and found that aiRange is a good node to use to control the fall off of aiCellNoise.
Nachricht 11 von 11
am_wilkins
als Antwort auf: stella_ng24GWZ
Cool!
Unfortunately, still doesn't smooth the edges of the voronoi pattern.
