Arnold General Rendering Forum
UV xgen hair
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
zenop
1172 Aufrufe, 2 Antworten
UV xgen hair
When adding a ramp to the hair shader, I am able to break up the individual surfaces of the hair. When adding a fractal/texture, it responds differently. Instead we get global changes in colour.
Usually this is the desired route. But I would like to break up the individual hairs with a fractal node very much like we can with a ramp. Is there any control over how the UV space of these textures gets interpreted? How does this work?
If I render a curve through a curvecollector, I get the results I am looking for.
Tags (4)
Beschriftungen (4)
2 ANTWORTEN 2
Nachricht 2 von 3
lee_griggs
als Antwort auf: zenop
Currently, Implicit UVs are only available in the Extra Attributes of the Ramp.
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 3 von 3
zenop
For others struggling with this:
All I had to do was modify the shader code to use the barycentric coordinates instead of the default UVs. The barycentric coordinates provide the root to tip mapping that I was looking for.
