Arnold General Rendering Forum
UV_Projection, shrink-wrap doesn’t stick to surface
0 ANTWORTEN 0
Nachricht 1 von 1
gremmler
204 Aufrufe, 0 Antworten
Hi, I’m trying to reconstruct a C4D shrink-wrap mapping in an Arnold shader. In C4D, the shrink-warp automatically sticks to the surface when the mesh deforms, but in Arnold, it swims. There is the P function (https://docs.arnoldrenderer.com/display/A5AFCUG/UV+Projection) that should actually fix that, but I don’t really understand how to make this work or what to feed into the P parameter to make it appear exactly as the native C4D mapping.
In theory, simply creating a UV tag should solve the problem, but I need the flexibility to animate certain matrix coordinates in the native C4D noise shrink-wrap mapping that displaces the mesh, which needs to correlate with the Arnold shader. Is that possible? Or maybe there is an example that illustrates how to use the P coordinates for that. Many thanks!
PS: Here is a simplified example scene illustrating the problem: uv-projection-problem-1.zip
0 ANTWORTEN 0
