Arnold General Rendering Forum
Using Texture Maps with Specular Roughness
12 ANTWORTEN 12
Nachricht 1 von 13
sketchguy
14240 Aufrufe, 12 Antworten
Hello!, I'm wanting to use grunge/scratch/fingerprint texture maps to break up the Specular Roughness in the aiStandard Shader, similar to this:
I’ve been doing some tests, but not getting the expected results. The texture map i’m using is a 16 bit Grayscale image. I also converted it to an RGB image and connected the R channel to the Specular Roughness, but still not getting the expected results. Is there something obvious i’m missing?
First image is basic shader with some Roughness dialed in:
Second image is with the R channel of the texture map assigned to Specular Roughness. I'm not getting the desired results.
Any suggestions fully appreciated!
Thx,
-Steve
Tags (2)
Beschriftungen (2)
12 ANTWORTEN 12
Nachricht 2 von 13
Stephen.Blair
als Antwort auf: sketchguy
I tried with a few random textures and they all affected the specular roughness in my test scene.
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 13
Have you set the Roughness map to Linear instead of sRGB?
Nachricht 4 von 13
sketchguy
als Antwort auf: Stephen.Blair
Hey Stephen, could you kindly post a screen shot of your Hypershade window with the aiStandardSurface shader selected, along with an image? I'd love to see what i'm not doing correctly. Thx!
Nachricht 5 von 13
sketchguy
als Antwort auf: Anonymous
Hey Dade, I can't seem to access The Color Space section in Image Attributes in the aiImage node when it's connected. When I delete the connection, I see four different Linear options - selecting each one, reconnecting and rendering doesn't seem to change anything that much at all.
Nachricht 6 von 13
lee_griggs
Hi Steve, have you tried adding a remap or Range shader in between the texture and the Standard Surface.
I did a recent test here.
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 7 von 13
Slava_91
Hi Steve!
Tried to connect luminance node on and graph network
Nachricht 8 von 13
I find that I need to put the Spec Roughness texture in the R channel of the texture file, with pure black in the Blue and Green channels. Then when I connect the spec rough map up via the r channel it works fine.
Nachricht 9 von 13
koostic.moloco
I dont have a bunch of settings in aiRange. Like Contrast Pivot and others... Nedd help.
Nachricht 10 von 13
lee_griggs
Have you updated your plugin?
Lee Griggs
AUTODESK
Nachricht 11 von 13
koostic.moloco
als Antwort auf: lee_griggs
I use Maya 2018. How can i update plugin? where? sorry, i am new in Maya, just study. I would be very grateful for the details
Nachricht 12 von 13
koostic.moloco
I use these. Will try to update. Thanks a lot
Nachricht 13 von 13
koostic.moloco
You are you a wizard. Thanks a lot. Updated it. Works nice.!
