Arnold General Rendering Forum
Trace Set not working with SSS Shaders
5 ANTWORTEN 5
Nachricht 1 von 6
arnold_user123
557 Aufrufe, 5 Antworten
Hey There,
I have a simple scene of 2 cubes and an area light. I have setup my trace set so the green cube should not cast onto the red cube. This works as intended with a standard surface with no sss, but when I add sss, it no longer works, see reference images:
Working trace set - no sss on red cube:
SSS on red cube breaking the trace set:
However, if I set the object to be thin walled, the trace set begins working again.
Here is the very basic shader setup on the red cube:
Is it possible to use an arnold trace set in conjunction with non-thin walled SSS shaders?
This happens both in maya and katana
Thank you
5 ANTWORTEN 5
Nachricht 2 von 6
arnold_user123
als Antwort auf: arnold_user123
Added detail, this is using MtoA 5.3.3.3 and KtoA 4.2.3.3, Arnold 7.2.3.3
Nachricht 3 von 6
Stephen.Blair
Hello arnold_user123
SSS doesn't use the trace_sets mechanism, SSS uses the sss_setnames
// Stephen Blair
// Arnold Renderer Support
Nachricht 4 von 6
arnold_user123
SSS_setnames as I understand it refers to unifying several objects' ss properties to aid the blurring/smoothing at intersections
Does this mean if I want to achieve the same affect as the first image, removing the shadow being cast from an object onto an sss object, that is not currently possible?
Nachricht 5 von 6
Stephen.Blair
SSS doesn't use the standard trace sets, so no.
// Stephen Blair
Nachricht 6 von 6
arnold_user123
Is there another possible way to achieve the same effect, without trace set? Perhaps with a ray switch?
I know I can turn off shadow casting for an object, but that stops casting from that object onto any object, as opposed to a specific one. Same with a ray switch
If anyone has any ideas that'd be great!
