Arnold General Rendering Forum
Toon shading and layering textures
1 ANTWORT 1
Nachricht 1 von 2
1405 Aufrufe, 1 Antwort
Do you know any way I can do toon shading while layering textures on top of it?
I am using tutorial for the toon shading: https://support.solidangle.com/display/A5AFMUG/Toon+Shading+with+the+Facing+Ratio+shader). I want to layer other textures (eyes, eyebrows and mouth) on top of it. While the toon shading works by itself, all my attempts to add layers have failed: I tried layered texture or shader but every time my model goes completely black. It doesn't seem to be a problem with the alpha mask. It might be some a problem with using Arnold and Maya materials together. However I'm not sure anymore as I've tried everything that came to mind.
Beschriftungen (5)
1 ANTWORT 1
Nachricht 2 von 2
lee_griggs
als Antwort auf: Anonymous
Whats your shading network look like? Why are you using Maya shaders?
Have you tried using the Mix shader?
Lee Griggs
Arnold rendering specialist
AUTODESK
