the relative texture path seems to have stopped working since mtoa 5.1.0.
I have a file that works fine with 5.0.0.4 but does not find its textures in any of the recent mtoas. I checked the ass files and they look identical so I guess it must be some error in the core.
options
texture_searchpath "/rakete/projects/mtpD:/srv/projects/btf/work/defaultSandbox/nrehberg/maya/sourceimages"
name aiImage1
filename "/library/assets/character/chMoses/lookDev/lookDev/textures/mtpD_chMoses_lookDev-lookDev_bandanaCOL-TXT_v001.1001.tx"
color_space ""
missing_texture_color 0 0 0 1
All good on 7.0.0.3
00:00:00 870MB | log started Thu Jul 28 17:26:17 2022
00:00:00 870MB | Arnold 7.0.0.3 [ccc33ba9] linux clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2022/02/16 18:14:43
00:00:00 870MB | running on fawaris, pid=141341
00:00:00 371MB | Image file statistics:
00:00:00 371MB | opens tiles MB read --redundant-- I/O time res File
00:00:00 371MB | 1 1 124 2.9 0.1s 4096x4096x3.f16 /rakete/projects/mtpD/library/assets/character/chMoses/lookDev/lookDev/textures/mtpD_chMoses_lookDev-lookDev_bandanaCOL-TXT_v001.1001.tx MIP-COUNT[0,0,54,44,15,4,1,1,1,1,1,1,1]
00:00:00 371MB | 2 1 100 2.3 0.0s 400x 800x3.f16 /rakete/projects/mtpD/library/assets/character/chMoses/lookDev/lookDev/textures/split.tx MIP-COUNT[62,22,8,2,1,1,1,1,1,1]
00:00:00 371MB |
00:00:00 371MB | Tot: 2 224 5.2 ( 0 0.0) 0.2s
00:00:00 371MB | Broken or invalid files: 0
00:00:00 371MB | -----------------------------------------------------------------------------------
Error on 7.1.2.2
00:00:00 860MB | log started Thu Jul 28 17:17:48 2022
00:00:00 860MB | Arnold 7.1.2.2 [c0d36bf9] linux clang-10.0.1 oiio-2.4.0 osl-1.12.0 vdb-7.1.1 adlsdk-6.3.1.44 clmhub-2.0.0.235 rlm-14.1.3 optix-6.6.0 2022/07/06 23:26:53
00:00:00 860MB | running on fawaris, pid=139566
ERROR | [texturesys] aiImage2: Could not open file: /library/assets/character/chMoses/lookDev/lookDev/textures/split.tx: No such file or directory
Invalid image file "/library/assets/character/chMoses/lookDev/lookDev/textures/split.tx": Could not open file: /library/assets/character/chMoses/lookDev/lookDev/textures/split.tx: No such file or directory
ERROR | [texturesys] aiImage2: Invalid image file "/library/assets/character/chMoses/lookDev/lookDev/textures/split.tx": Could not open file: /library/assets/character/chMoses/lookDev/lookDev/textures/split.tx: No such file or directory
ERROR | [texturesys] aiImage1: Could not open file: /library/assets/character/chMoses/lookDev/lookDev/textures/mtpD_chMoses_lookDev-lookDev_bandanaCOL-TXT_v001.1001.tx: No such file or directory
Invalid image file "/library/assets/character/chMoses/lookDev/lookDev/textures/mtpD_chMoses_lookDev-lookDev_bandanaCOL-TXT_v001.1001.tx": Could not open file: /library/assets/character/chMoses/lookDev/lookDev/textures/mtpD_chMoses_lookDev-lookDev_bandanaCOL-TXT_v001.1001.tx: No such file or directory
ERROR | [texturesys] aiImage1: Invalid image file "/library/assets/character/chMoses/lookDev/lookDev/textures/mtpD_chMoses_lookDev-lookDev_bandanaCOL-TXT_v001.1001.tx": Could not open file: /library/assets/character/chMoses/lookDev/lookDev/textures/mtpD_chMoses_lookDev-lookDev_bandanaCOL-TXT_v001.1001.tx: No such file or directory
Or was there something changed?
Nico
Gelöst! Gehe zur Lösung
Gelöst von thiago.ize. Gehe zur Lösung
I don't see how that ever worked. There's an absolute path for image.filename, not relative. It never should have worked.
Strangely it did for us forever. Seems like it was concatenating the paths just fine, not caring about that forward slash at the beginning.
But you are right, removing the first forward slash in the texture path makes it work. So something must have changed in the core.
Thanks for the hint. Too bad it won't help with the old files.
Nico
I tried with Arnold 6.1, 7.0.0.3, and 7.1.2.1, and none of them worked with an image.filename like "/examples/test_texture.tif"
Fascinating. It just works here. As I said we've been using it for years. Made whole movies like this.
I boiled it down to a very simple .ass and threw that against multiple kicks in a clean commandline. And it always works up until 7.1.0.0
options
outputs "RGBA RGBA defaultArnoldFilter/gaussian_filter defaultArnoldDriver/driver_exr.RGBA"
xres 960
yres 540
texture_per_file_stats on
texture_searchpath "/rakete/projects/mtpD"
gaussian_filter
name defaultArnoldFilter/gaussian_filter
driver_exr
name defaultArnoldDriver/driver_exr.RGBA
filename "/srv/projects/btf/work/defaultSandbox/nrehberg/maya/images/relativeTexPath.exr"
persp_camera
matrix
0.99984771 4.33680869e-19 0.0174524058 0
0.00752 0.902296901 -0.431049526 0
-0.0157472529 0.43111518 0.902159452 0
0.0997361541 3.73596621 8.20834827 1
fov 54.4322243
skydome_light
camera 0
sphere
radius 2.0
shader "aiStandardSurface1"
standard_surface
name aiStandardSurface1
base_color aiImage2
name aiImage2
filename "/library/assets/character/chMoses/lookDev/lookDev/textures/split.tx"
Here's the command line results
bash-4.4$ /rakete/tools/installs/lx64/maya/plugins/mtoa/4.0.0.0/2020/bin/kick relativeTexPath.ass -dp -v 3
00:00:00 128MB | log started Fri Jul 29 09:34:08 2022
00:00:00 128MB | Arnold 6.0.0.0 [ddee0ddd] linux clang-5.0.0 oiio-2.1.4 osl-1.11.0 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.5.0 2019/11/07 15:01:06
00:00:00 128MB | running on fawaris, pid=183745
00:00:00 128MB | 1 x AMD Ryzen 9 5950X 16-Core Processor (16 cores, 32 logical) with 128566MB
00:00:00 128MB | NVIDIA driver version 510.68 (Optix 60802)
00:00:00 128MB | GPU 0: NVIDIA GeForce RTX 3060 @ 1777MHz (compute 8.6) with 12050MB (7581MB available) (NVLink:0)
00:00:00 128MB | Rocky Linux 8.6 (Green Obsidian), Linux kernel 4.18.0-372.9.1.el8.x86_64
00:00:00 128MB | soft limit for open files raised from 262142 to 262142
00:00:00 128MB |
00:00:00 128MB | loading plugins from /rakete/tools/installs/lx64/maya/plugins/mtoa/4.0.0.0/2020/bin/../plugins ...
00:00:00 128MB | loaded 5 plugins from 3 lib(s) in 0:00.00
00:00:00 128MB | [kick] command: /rakete/tools/installs/lx64/maya/plugins/mtoa/4.0.0.0/2020/bin/kick relativeTexPath.ass -dp -v 3
00:00:00 128MB | loading plugins from . ...
00:00:00 128MB | no plugins loaded
00:00:00 129MB | [ass] loading relativeTexPath.ass ...
00:00:00 129MB | [ass] read 869 bytes, 8 nodes in 0:00.00
00:00:00 129MB |
00:00:00 129MB | authorizing with default license managers: rlm, network, user ...
00:00:00 134MB | [network] authorized for "87287ARNOL_2020_0F" in 0:00.02
00:00:00 134MB | [network] expiration date: 2022/08/26, in use: 1/190
00:00:00 134MB |
00:00:00 134MB | [color_manager] no color manager is active
00:00:00 134MB | [color_manager] rendering color space is "linear" with declared chromaticities:
00:00:00 134MB | r(0.6400, 0.3300) g(0.3000, 0.6000) b(0.1500, 0.0600) and w(0.3127, 0.3290)
00:00:00 147MB |
00:00:00 147MB | there are 1 light and 2 objects:
00:00:00 147MB | 1 persp_camera
00:00:00 147MB | 1 skydome_light
00:00:00 147MB | 1 image
00:00:00 147MB | 1 utility
00:00:00 147MB | 1 standard_surface
00:00:00 147MB | 1 driver_exr
00:00:00 147MB | 1 gaussian_filter
00:00:00 147MB | 1 sphere
00:00:00 147MB | 1 list_aggregate
00:00:00 147MB | 1 driver_kick
00:00:00 147MB |
00:00:00 147MB | rendering image at 960 x 540, 1 AA sample
00:00:00 147MB | AA samples max <disabled>
00:00:00 147MB | AA sample clamp <disabled>
00:00:00 147MB | diffuse <disabled by depth>
00:00:00 147MB | specular <disabled by depth>
00:00:00 147MB | transmission samples 2 / depth 2
00:00:00 147MB | volume indirect <disabled by depth>
00:00:00 147MB | total depth 10
00:00:00 147MB | bssrdf samples 2
00:00:00 147MB | transparency depth 10
00:00:00 147MB | initializing 11 nodes ...
00:00:00 147MB | creating root object list ...
00:00:00 147MB | node initialization done in 0:00.00 (multithreaded)
00:00:00 147MB | updating 12 nodes ...
00:00:00 147MB | : skydome_light using 1 sample, 2 volume samples
00:00:00 147MB | scene bounds: (-2 -2 -2) -> (2 2 2)
00:00:00 147MB | node update done in 0:00.00 (multithreaded)
00:00:00 147MB | [aov] parsing 2 output statements ...
00:00:00 147MB | [aov] registered driver: "defaultArnoldDriver/driver_exr.RGBA" (driver_exr)
00:00:00 147MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:00:00 147MB | [aov] registered driver: "kick_display" (driver_kick)
00:00:00 147MB | [aov] done preparing 2 AOVs for 2 outputs to 2 drivers (0 deep AOVs)
00:00:00 192MB | starting 32 bucket workers of size 64x64 ...
00:00:00 199MB | 0% done - 120 rays/pixel
00:00:00 200MB | 5% done - 28 rays/pixel
00:00:00 201MB | 10% done - 4 rays/pixel
00:00:00 205MB | 15% done - 1 rays/pixel
00:00:00 205MB | 20% done - 1 rays/pixel
00:00:00 206MB | 25% done - 0 rays/pixel
00:00:00 206MB | 30% done - 2 rays/pixel
00:00:00 207MB | 35% done - 3 rays/pixel
00:00:00 207MB | 40% done - 2 rays/pixel
00:00:00 207MB | 45% done - 1 rays/pixel
00:00:00 207MB | 50% done - 1 rays/pixel
00:00:00 208MB | 55% done - 1 rays/pixel
00:00:00 209MB | 60% done - 1 rays/pixel
00:00:00 210MB | 65% done - 2 rays/pixel
00:00:00 210MB | 70% done - 2 rays/pixel
00:00:00 212MB | 75% done - 2 rays/pixel
00:00:00 212MB | 80% done - 0 rays/pixel
00:00:00 212MB | 85% done - 1 rays/pixel
00:00:00 213MB | 90% done - 0 rays/pixel
00:00:00 213MB | 95% done - 0 rays/pixel
00:00:00 213MB | 100% done - 0 rays/pixel
00:00:00 213MB | render done in 0:00.144
00:00:00 213MB | [driver_exr] writing file `/srv/projects/btf/work/defaultSandbox/nrehberg/maya/images/relativeTexPath.exr'
00:00:00 213MB |
00:00:00 213MB | -----------------------------------------------------------------------------------
00:00:00 213MB | scene creation time 0:00.02 machine utilization (0.67%)
00:00:00 213MB | unaccounted 0:00.01
00:00:00 213MB | frame time 0:00.35 machine utilization (15.26%)
00:00:00 213MB | driver init/close 0:00.16
00:00:00 213MB | rendering 0:00.14
00:00:00 213MB | output driver 0:00.08
00:00:00 213MB | pixel rendering 0:00.05
00:00:00 213MB | unaccounted 0:00.04
00:00:00 213MB | top session self-times by category
00:00:00 213MB | worker waiting 0:00.16 (55.50%)
00:00:00 213MB | thread blocked 0:00.08 (27.27%)
00:00:00 213MB | surface closure (aiStandardSurface1) 0:00.00 ( 3.27%)
00:00:00 213MB | ray traversal+intersection 0:00.00 ( 2.75%)
00:00:00 213MB | AiTextureHandleAccess 0:00.00 ( 2.12%)
00:00:00 213MB | processBucketSamples 0:00.00 ( 2.04%)
00:00:00 213MB | top session self-times by node
00:00:00 213MB | standard_surface:aiStandardSurface1 0:00.02 ( 7.38%)
00:00:00 213MB | surface closure 0:00.00 ( 3.27%)
00:00:00 213MB | ray traversal+intersection 0:00.00 ( 2.01%)
00:00:00 213MB | TraceShadow 0:00.00 ( 0.56%)
00:00:00 213MB | image:aiImage2 0:00.00 ( 2.18%)
00:00:00 213MB | driver_kick:kick_display 0:00.00 ( 1.76%)
00:00:00 213MB | driver_open 0:00.00 ( 1.41%)
00:00:00 213MB | peak CPU memory used 213.28MB
00:00:00 213MB | at startup 104.68MB
00:00:00 213MB | plugins 23.35MB
00:00:00 213MB | AOV samples 17.94MB
00:00:00 213MB | output buffers 4.00MB
00:00:00 213MB | framebuffers 16.88MB
00:00:00 213MB | node overhead 0.01MB
00:00:00 213MB | message passing 0.06MB
00:00:00 213MB | memory pools 26.05MB
00:00:00 213MB | geometry 0.00MB
00:00:00 213MB | strings 24.25MB
00:00:00 213MB | texture cache 1.15MB
00:00:00 213MB | profiler 0.07MB
00:00:00 213MB | unaccounted -5.16MB
00:00:00 213MB | ray counts ( /pixel, /sample) (% total) (avg. hits) (max hits)
00:00:00 213MB | camera 551880 ( 1.06, 1.00) ( 31.41%) ( 0.27) ( 1)
00:00:00 213MB | shadow 1205045 ( 2.32, 2.18) ( 68.59%) ( 0.00) ( 0)
00:00:00 213MB | total 1756925 ( 3.39, 3.18) (100.00%) ( 0.09) ( 1)
00:00:00 213MB | by ray depth: 0
00:00:00 213MB | total 100.0%
00:00:00 213MB | shader calls ( /pixel, /sample) (% total)
00:00:00 213MB | primary 301716 ( 0.58, 0.55) (100.00%)
00:00:00 213MB | total 301716 ( 0.58, 0.55) (100.00%)
00:00:00 213MB | geometry (% hit ) (instances) ( init mem, final mem)
00:00:00 213MB | lists 1 (100.0%) ( 0) ( 0.00, 0.00)
00:00:00 213MB | simple 1 (100.0%) ( 0) ( 0.00, 0.00)
00:00:00 213MB | OpenImageIO Texture statistics
00:00:00 213MB | Options: gray_to_rgb=1 flip_t=0 max_tile_channels=6
00:00:00 213MB | Queries/batches :
00:00:00 213MB | texture : 150858 queries in 150858 batches
00:00:00 213MB | texture 3d : 0 queries in 0 batches
00:00:00 213MB | shadow : 0 queries in 0 batches
00:00:00 213MB | environment : 0 queries in 0 batches
00:00:00 213MB | gettextureinfo : 0 queries
00:00:00 213MB | Interpolations :
00:00:00 213MB | closest : 0
00:00:00 213MB | bilinear : 0
00:00:00 213MB | bicubic : 150858
00:00:00 213MB | Average anisotropic probes : 1
00:00:00 213MB | Max anisotropy in the wild : 1
00:00:00 213MB |
00:00:00 213MB | OpenImageIO ImageCache statistics (0x7fdd3a89a000) ver 2.1.4dev
00:00:00 213MB | Options: max_memory_MB=2048.0 max_open_files=261630 autotile=0
00:00:00 213MB | autoscanline=1 automip=1 forcefloat=0 accept_untiled=1
00:00:00 213MB | accept_unmipped=1 deduplicate=1 unassociatedalpha=0
00:00:00 213MB | failure_retries=0
00:00:00 213MB | Images : 1 unique
00:00:00 213MB | ImageInputs : 1 created, 1 current, 1 peak
00:00:00 213MB | Total pixel data size of all images referenced : 2.4 MB
00:00:00 213MB | Total actual file size of all images referenced : 207 KB
00:00:00 213MB | Pixel data read : 1.1 MB
00:00:00 213MB | File I/O time : 0.0s (0.0s average per thread, for 32 threads)
00:00:00 213MB | File open time only : 0.0s
00:00:00 213MB | ImageInput mutex locking time : 0.0s
00:00:00 213MB | Tiles: 49 created, 49 current, 49 peak
00:00:00 213MB | total tile requests : 221023
00:00:00 213MB | micro-cache misses : 201 (0.0909408%)
00:00:00 213MB | main cache misses : 49 (0.0221696%)
00:00:00 213MB | redundant reads: 0 tiles, 0 B
00:00:00 213MB | Peak cache memory : 1.1 MB
00:00:00 213MB | Image file statistics:
00:00:00 213MB | opens tiles MB read --redundant-- I/O time res File
00:00:00 213MB | 1 1 49 1.1 0.0s 400x 800x3.f16 /rakete/projects/mtpD/library/assets/character/chMoses/lookDev/lookDev/textures/split.tx MIP-UNUSED MIP-COUNT[49,0,0,0,0,0,0,0,0,0]
00:00:00 213MB |
00:00:00 213MB | Tot: 1 49 1.1 ( 0 0.0) 0.0s
00:00:00 213MB | Broken or invalid files: 0
00:00:02 217MB |
00:00:02 217MB | releasing resources
00:00:02 205MB | Arnold shutdown
bash-4.4$ /rakete/tools/installs/lx64/maya/plugins/mtoa/5.0.0.4/2020/bin/kick relativeTexPath.ass -dp -v 3
00:00:00 109MB | log started Fri Jul 29 09:34:19 2022
00:00:00 109MB | Arnold 7.0.0.3 [ccc33ba9] linux clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2022/02/16 18:14:43
00:00:00 109MB | running on fawaris, pid=183859
00:00:00 109MB | 1 x AMD Ryzen 9 5950X 16-Core Processor (16 cores, 32 logical) with 128566MB
00:00:00 109MB | NVIDIA driver version 510.68 (Optix 60802)
00:00:00 109MB | GPU 0: NVIDIA GeForce RTX 3060 @ 1777MHz (compute 8.6) with 12050MB (7581MB available) (NVLink:0)
00:00:00 109MB | Rocky Linux 8.6 (Green Obsidian), Linux kernel 4.18.0-372.9.1.el8.x86_64
00:00:00 109MB | soft limit for open files is set at 262142
00:00:00 109MB |
00:00:00 111MB | [color_manager_ocio] default ocio.config found in /rakete/tools/installs/lx64/maya/plugins/mtoa/5.0.0.4/2020/bin/../ocio/configs/arnold/config.ocio
00:00:00 111MB | loading plugins from /rakete/tools/installs/lx64/maya/plugins/mtoa/5.0.0.4/2020/bin/../plugins ...
00:00:00 120MB | loaded 6 plugins from 4 lib(s) in 0:00.00
00:00:00 120MB | [color_manager_ocio] default ocio.config found in /rakete/tools/installs/lx64/maya/plugins/mtoa/5.0.0.4/2020/bin/../ocio/configs/arnold/config.ocio
00:00:00 136MB | [kick] command: /rakete/tools/installs/lx64/maya/plugins/mtoa/5.0.0.4/2020/bin/kick relativeTexPath.ass -dp -v 3
00:00:00 136MB | loading plugins from . ...
00:00:00 136MB | no plugins loaded
00:00:00 137MB | [ass] loading relativeTexPath.ass ...
00:00:00 138MB | [ass] read 869 bytes, 8 nodes in 0:00.00
00:00:00 138MB |
00:00:00 138MB | authorizing with default license managers: rlm, network, user ...
00:00:00 143MB | [network] authorized for "87616ARNOL_2022_0F" in 0:00.02
00:00:00 143MB | [network] expiration date: 2022/08/26, in use: 34/190
00:00:00 143MB |
00:00:00 143MB | [color_manager] using color manager of type "color_manager_ocio"
00:00:00 144MB | [color_manager_ocio] using config file /rakete/tools/installs/lx64/maya/plugins/mtoa/5.0.0.4/2020/bin/../ocio/configs/arnold/config.ocio
00:00:00 144MB | [color_manager] rendering color space is "ACEScg"
00:00:00 157MB |
00:00:00 157MB | there are 1 light and 2 objects:
00:00:00 157MB | 1 persp_camera
00:00:00 157MB | 1 skydome_light
00:00:00 157MB | 1 image
00:00:00 157MB | 2 utility
00:00:00 157MB | 1 standard_surface
00:00:00 157MB | 1 driver_exr
00:00:00 157MB | 1 gaussian_filter
00:00:00 157MB | 1 sphere
00:00:00 157MB | 2 list_aggregate
00:00:00 157MB | 2 color_manager_ocio
00:00:00 157MB | 1 driver_kick
00:00:00 157MB |
00:00:00 157MB | rendering image at 960 x 540, 1 AA sample
00:00:00 157MB | AA samples max <disabled>
00:00:00 157MB | AA sample clamp <disabled>
00:00:00 157MB | diffuse <disabled by depth>
00:00:00 157MB | specular <disabled by depth>
00:00:00 157MB | transmission samples 2 / depth 2
00:00:00 157MB | volume indirect <disabled by depth>
00:00:00 157MB | total depth 10
00:00:00 157MB | bssrdf samples 2
00:00:00 157MB | transparency depth 10
00:00:00 157MB | initializing 12 nodes ...
00:00:00 157MB | creating root object list ...
00:00:00 157MB | node initialization done in 0:00.00 (multithreaded)
00:00:00 157MB | updating 13 nodes ...
00:00:00 157MB | : skydome_light using 1 sample, 2 volume samples
00:00:00 160MB | scene bounds: (-2 -2 -2) -> (2 2 2)
00:00:00 160MB | node update done in 0:00.00 (multithreaded)
00:00:00 160MB | [aov] parsing 2 output statements ...
00:00:00 160MB | [aov] registered driver: "defaultArnoldDriver/driver_exr.RGBA" (driver_exr)
00:00:00 160MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:00:00 160MB | [aov] registered driver: "kick_display" (driver_kick)
00:00:00 160MB | [aov] done preparing 2 AOVs for 1 output to 2 drivers (0 deep AOVs)
00:00:00 197MB | starting 32 bucket workers of size 64x64 ...
00:00:00 233MB | 0% done - 103 rays/pixel
00:00:00 239MB | 5% done - 23 rays/pixel
00:00:00 240MB | 10% done - 3 rays/pixel
00:00:00 241MB | 15% done - 4 rays/pixel
00:00:00 242MB | 20% done - 3 rays/pixel
00:00:00 242MB | 25% done - 0 rays/pixel
00:00:00 242MB | 30% done - 2 rays/pixel
00:00:00 243MB | 35% done - 2 rays/pixel
00:00:00 243MB | 40% done - 1 rays/pixel
00:00:00 244MB | 45% done - 2 rays/pixel
00:00:00 245MB | 50% done - 2 rays/pixel
00:00:00 245MB | 55% done - 1 rays/pixel
00:00:00 246MB | 60% done - 1 rays/pixel
00:00:00 246MB | 65% done - 1 rays/pixel
00:00:00 248MB | 70% done - 2 rays/pixel
00:00:00 248MB | 75% done - 1 rays/pixel
00:00:00 249MB | 80% done - 1 rays/pixel
00:00:00 249MB | 85% done - 1 rays/pixel
00:00:00 249MB | 90% done - 1 rays/pixel
00:00:00 249MB | 95% done - 1 rays/pixel
00:00:00 250MB | 100% done - 0 rays/pixel
00:00:00 250MB | render done in 0:00.130
00:00:00 250MB | [driver_exr] writing file `/srv/projects/btf/work/defaultSandbox/nrehberg/maya/images/relativeTexPath.exr'
00:00:00 250MB |
00:00:00 250MB | -----------------------------------------------------------------------------------
00:00:00 250MB | scene creation time 0:00.12 machine utilization (0.09%)
00:00:00 250MB | unaccounted 0:00.12
00:00:00 250MB | frame time 0:00.32 machine utilization (16.61%)
00:00:00 250MB | driver init/close 0:00.14
00:00:00 250MB | rendering 0:00.13
00:00:00 250MB | output driver 0:00.06
00:00:00 250MB | pixel rendering 0:00.06
00:00:00 250MB | unaccounted 0:00.04
00:00:00 250MB | top session self-times by category
00:00:00 251MB | thread blocked 0:00.06 (47.90%)
00:00:00 251MB | surface closure (aiStandardSurface1) 0:00.00 ( 7.41%)
00:00:00 251MB | ray traversal+intersection 0:00.00 ( 6.79%)
00:00:00 251MB | accumulateBucketSamples 0:00.00 ( 4.39%)
00:00:00 251MB | standard_surface (aiStandardSurface1) 0:00.00 ( 4.33%)
00:00:00 251MB | AiLightsTrace 0:00.00 ( 4.04%)
00:00:00 251MB | TraceCameraRay 0:00.00 ( 3.88%)
00:00:00 251MB | AiTextureHandleAccess 0:00.00 ( 3.28%)
00:00:00 251MB | driver_open 0:00.00 ( 3.19%)
00:00:00 251MB | kick_display 0:00.00 ( 2.85%)
00:00:00 251MB | AiSceneLoad 0:00.00 ( 2.51%)
00:00:00 251MB | sampleNextBatch 0:00.00 ( 2.40%)
00:00:00 251MB | driver_write_bucket (defaultArnoldDriver/driver_exr.RGBA) 0:00.00 ( 2.36%)
00:00:00 251MB | -----------------------------------------------------------------------------------
00:00:00 251MB | top session self-times by node
00:00:00 251MB | thread blocked 0:00.06 (46.45%)
00:00:00 251MB | standard_surface:aiStandardSurface1 0:00.03 (23.35%)
00:00:00 251MB | surface closure 0:00.00 ( 7.41%)
00:00:00 251MB | ray traversal+intersection 0:00.00 ( 5.02%)
00:00:00 251MB | TraceShadow 0:00.00 ( 1.50%)
00:00:00 251MB | AiMakeRay 0:00.00 ( 0.75%)
00:00:00 251MB | image:aiImage2 0:00.00 ( 5.44%)
00:00:00 251MB | thread blocked 0:00.00 ( 1.45%)
00:00:00 251MB | driver_kick:kick_display 0:00.00 ( 3.43%)
00:00:00 251MB | driver_open 0:00.00 ( 2.85%)
00:00:00 251MB | AiColorManagerTransform 0:00.00 ( 0.53%)
00:00:00 251MB | driver_exr:defaultArnoldDriver/driver_exr.RGBA 0:00.00 ( 3.04%)
00:00:00 251MB | driver_write_bucket 0:00.00 ( 2.36%)
00:00:00 251MB | peak CPU memory used 250.97MB
00:00:00 251MB | at startup 109.73MB
00:00:00 251MB | AOV samples 4.53MB
00:00:00 251MB | output buffers 2.00MB
00:00:00 251MB | framebuffers 8.44MB
00:00:00 251MB | node overhead 0.01MB
00:00:00 251MB | message passing 0.06MB
00:00:00 251MB | memory pools 57.55MB
00:00:00 251MB | geometry 0.00MB
00:00:00 251MB | strings 24.25MB
00:00:00 251MB | texture cache 1.15MB
00:00:00 251MB | profiler 0.10MB
00:00:00 251MB | unaccounted 43.15MB
00:00:00 251MB | ray counts ( /pixel, /sample) (% total) (avg. hits) (max hits)
00:00:00 251MB | camera 551880 ( 1.06, 1.00) ( 31.41%) ( 0.27) ( 1)
00:00:00 251MB | shadow 1205045 ( 2.32, 2.18) ( 68.59%) ( 0.00) ( 0)
00:00:00 251MB | total 1756925 ( 3.39, 3.18) (100.00%) ( 0.09) ( 1)
00:00:00 251MB | by ray depth: 0
00:00:00 251MB | total 100.0%
00:00:00 251MB | shader calls ( /pixel, /sample) (% total)
00:00:00 251MB | primary 301716 ( 0.58, 0.55) (100.00%)
00:00:00 251MB | total 301716 ( 0.58, 0.55) (100.00%)
00:00:00 251MB | geometry (% hit ) (instances) ( init mem, final mem)
00:00:00 251MB | lists 1 (100.0%) ( 0) ( 0.00, 0.00)
00:00:00 251MB | simple 1 (100.0%) ( 0) ( 0.00, 0.00)
00:00:00 251MB | OpenImageIO Texture statistics
00:00:00 251MB | Options: gray_to_rgb=1 flip_t=0 max_tile_channels=6
00:00:00 251MB | Queries/batches :
00:00:00 251MB | texture : 150858 queries in 150858 batches
00:00:00 251MB | texture 3d : 0 queries in 0 batches
00:00:00 251MB | shadow : 0 queries in 0 batches
00:00:00 251MB | environment : 0 queries in 0 batches
00:00:00 251MB | gettextureinfo : 0 queries
00:00:00 251MB | Interpolations :
00:00:00 251MB | closest : 0
00:00:00 251MB | bilinear : 0
00:00:00 251MB | bicubic : 150858
00:00:00 251MB | Average anisotropic probes : 1
00:00:00 251MB | Max anisotropy in the wild : 1
00:00:00 251MB |
00:00:00 251MB | OpenImageIO ImageCache statistics (0x7f90e8f1e000) ver 2.3.2dev
00:00:00 251MB | Options: max_memory_MB=4096.0 max_open_files=261630 autotile=0
00:00:00 251MB | autoscanline=1 automip=1 forcefloat=0 accept_untiled=1
00:00:00 251MB | accept_unmipped=1 deduplicate=1 unassociatedalpha=0
00:00:00 251MB | failure_retries=0
00:00:00 251MB | Images : 1 unique
00:00:00 251MB | ImageInputs : 1 created, 1 current, 1 peak
00:00:00 251MB | Total pixel data size of all images referenced : 2.4 MB
00:00:00 251MB | Total actual file size of all images referenced : 207 KB
00:00:00 251MB | Pixel data read : 1.1 MB
00:00:00 251MB | File I/O time : 0.1s (0.0s average per thread, for 32 threads)
00:00:00 251MB | File open time only : 0.0s
00:00:00 251MB | Tiles: 49 created, 49 current, 49 peak
00:00:00 251MB | total tile requests : 221023
00:00:00 251MB | micro-cache misses : 201 (0.0909408%)
00:00:00 251MB | main cache misses : 49 (0.0221696%)
00:00:00 251MB | redundant reads: 0 tiles, 0 B
00:00:00 251MB | Peak cache memory : 1.1 MB
00:00:00 251MB | Image file statistics:
00:00:00 251MB | opens tiles MB read --redundant-- I/O time res File
00:00:00 251MB | 1 1 49 1.1 0.1s 400x 800x3.f16 /rakete/projects/mtpD/library/assets/character/chMoses/lookDev/lookDev/textures/split.tx MIP-UNUSED MIP-COUNT[49,0,0,0,0,0,0,0,0,0]
00:00:00 251MB |
00:00:00 251MB | Tot: 1 49 1.1 ( 0 0.0) 0.1s
00:00:00 251MB | Broken or invalid files: 0
00:00:02 254MB |
00:00:02 254MB | releasing resources
00:00:02 197MB |
00:00:02 197MB | releasing resources
00:00:02 187MB | Arnold shutdown
bash-4.4$ /rakete/tools/installs/lx64/maya/plugins/mtoa/5.1.0/2023/bin/kick relativeTexPath.ass -dp -v 3
00:00:00 113MB | log started Fri Jul 29 09:34:42 2022
00:00:00 113MB | Arnold 7.1.0.0 [80afc20e] linux clang-10.0.1 oiio-2.4.0 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2022/02/10 17:12:29
00:00:00 113MB | running on fawaris, pid=183971
00:00:00 113MB | 1 x AMD Ryzen 9 5950X 16-Core Processor (16 cores, 32 logical) with 128566MB
00:00:00 113MB | NVIDIA driver version 510.68 (Optix 60802)
00:00:00 113MB | GPU 0: NVIDIA GeForce RTX 3060 @ 1777MHz (compute 8.6) with 12050MB (7571MB available) (NVLink:0)
00:00:00 113MB | Rocky Linux 8.6 (Green Obsidian), Linux kernel 4.18.0-372.9.1.el8.x86_64
00:00:00 113MB | soft limit for open files is set at 262142
00:00:00 113MB |
00:00:00 114MB | [color_manager_ocio] default ocio.config found in /rakete/tools/installs/lx64/maya/plugins/mtoa/5.1.0/2023/bin/../ocio/configs/arnold/config.ocio
00:00:00 114MB | loading plugins from /rakete/tools/installs/lx64/maya/plugins/mtoa/5.1.0/2023/bin/../plugins ...
00:00:00 123MB | loaded 6 plugins from 4 lib(s) in 0:00.00
00:00:00 123MB | [color_manager_ocio] default ocio.config found in /rakete/tools/installs/lx64/maya/plugins/mtoa/5.1.0/2023/bin/../ocio/configs/arnold/config.ocio
00:00:00 139MB | [kick] command: /rakete/tools/installs/lx64/maya/plugins/mtoa/5.1.0/2023/bin/kick relativeTexPath.ass -dp -v 3
00:00:00 139MB | loading plugins from . ...
00:00:00 139MB | no plugins loaded
00:00:00 141MB | [ass] loading relativeTexPath.ass ...
00:00:00 141MB | [ass] read 869 bytes, 8 nodes in 0:00.00
00:00:00 141MB |
00:00:00 141MB | authorizing with default license managers: rlm, network, user ...
00:00:00 146MB | [network] authorized for "87752ARNOL_2023_0F" in 0:00.11
00:00:00 146MB | [network] expiration date: 2022/08/26, in use: 1/190
00:00:00 146MB |
00:00:00 146MB | [color_manager] using color manager of type "color_manager_ocio"
00:00:00 147MB | [color_manager_ocio] using config file /rakete/tools/installs/lx64/maya/plugins/mtoa/5.1.0/2023/bin/../ocio/configs/arnold/config.ocio
00:00:00 148MB | [color_manager] rendering color space is "ACEScg"
00:00:00 160MB |
00:00:00 160MB | there are 1 light and 2 objects:
00:00:00 160MB | 1 persp_camera
00:00:00 160MB | 1 skydome_light
00:00:00 160MB | 1 image
00:00:00 160MB | 2 utility
00:00:00 160MB | 1 standard_surface
00:00:00 160MB | 1 driver_exr
00:00:00 160MB | 1 gaussian_filter
00:00:00 160MB | 1 sphere
00:00:00 160MB | 2 list_aggregate
00:00:00 160MB | 2 color_manager_ocio
00:00:00 160MB | 1 driver_kick
00:00:00 160MB |
00:00:00 160MB | rendering image at 960 x 540, 1 AA sample
00:00:00 160MB | AA samples max <disabled>
00:00:00 160MB | AA sample clamp <disabled>
00:00:00 160MB | diffuse <disabled by depth>
00:00:00 160MB | specular <disabled by depth>
00:00:00 160MB | transmission samples 2 / depth 2
00:00:00 160MB | volume indirect <disabled by depth>
00:00:00 160MB | total depth 10
00:00:00 160MB | bssrdf samples 2
00:00:00 160MB | transparency depth 10
00:00:00 160MB | initializing 12 nodes ...
00:00:00 161MB | creating root object list ...
00:00:00 161MB | node initialization done in 0:00.00 (multithreaded)
00:00:00 161MB | updating 13 nodes ...
00:00:00 161MB | : skydome_light using 1 sample, 2 volume samples
00:00:00 163MB | scene bounds: (-2 -2 -2) -> (2 2 2)
00:00:00 163MB | node update done in 0:00.00 (multithreaded)
00:00:00 163MB | [aov] parsing 2 output statements ...
00:00:00 163MB | [aov] registered driver: "defaultArnoldDriver/driver_exr.RGBA" (driver_exr)
00:00:00 163MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:00:00 163MB | [aov] registered driver: "kick_display" (driver_kick)
00:00:00 163MB | [aov] done preparing 2 AOVs for 1 output to 2 drivers (0 deep AOVs)
00:00:00 200MB | starting 32 bucket workers of size 64x64 ...
00:00:00 211MB ERROR | [texturesys] aiImage2: Could not open file: /library/assets/character/chMoses/lookDev/lookDev/textures/split.tx: No such file or directory
00:00:00 211MB ERROR | [texturesys] aiImage2: Invalid image file "/library/assets/character/chMoses/lookDev/lookDev/textures/split.tx": Could not open file: /library/assets/character/chMoses/lookDev/lookDev/textures/split.tx: No such file or directory
00:00:00 211MB WARNING | [kick] render aborted due to earlier errors
00:00:00 211MB WARNING | render terminating early: unknown reason
00:00:00 211MB | render done in 0:00.037
00:00:00 211MB | [driver_exr] writing file `/srv/projects/btf/work/defaultSandbox/nrehberg/maya/images/relativeTexPath.exr'
00:00:00 210MB |
00:00:00 210MB | releasing resources
00:00:00 210MB |
00:00:00 200MB | Arnold shutdown
bash-4.4$
In Arnold 7.1.0.0 we rewrote the search path code so that we could improve performance and make things more consistent across the various places arnold uses searchpaths. It looks like having a leading / or ./ in the filename no longer works.
I've created ARNOLD-12517 for fixing this. Thanks for the report!
With both Arnold 6.2 and Arnold 7.0.0.3, having an image.filename like /examples/test_texture.tif does not work.
Arnold does not add the texture_searchpath to that filename
Tested on macos
