Arnold General Rendering Forum
standard surface water material question
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
mhouse777s
279 Aufrufe, 3 Antworten
Is this a correct set up for water depth falloff? I feel like it's close but not optimal. Any help is appreciated. Insert photo doesn't seem to be working so I attached the image.
Thanks.
3 ANTWORTEN 3
Nachricht 2 von 4
lee_griggs
als Antwort auf: mhouse777s
You should be able to control the appearance using transmission_depth and transmission_color without having to use a falloff map. https://docs.arnoldrenderer.com/display/A5AF3DSUG/Transmission
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 3 von 4
mhouse777s
...so transmission_depth makes the water more opaque as the pond gets deeper? That's what I'm shooting for.
Nachricht 4 von 4
lee_griggs
Yes, here:
Lee Griggs
AUTODESK
