Arnold General Rendering Forum
Specular Weight
6 ANTWORTEN 6
Nachricht 1 von 7
Joseph_Kim
772 Aufrufe, 6 Antworten
Specular Weight
By setting your Specular Weight to anything less than value of 1 on standardSurface , does this break PBR??
What I am trying to achieve is to decrease the value of highlight on an object and I tried that with trying to set my roughness to 1 with no success.
Thanks for your help.
6 ANTWORTEN 6
Nachricht 2 von 7
lee_griggs
als Antwort auf: Joseph_Kim
Specular weight affects the brightness of the specular highlight, however, a lower amount of light should be reflected when using high roughness values.
What shading effect are you trying to achieve?
More information here:
Specularity BRDF
Understanding Physically Based Rendering in Arnold.
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 3 von 7
Joseph_Kim
Hi Lee,
I have specular roughness set to 1 and light reflected is still to high. What is the correct way to decrease the light being reflected?
Joe
Nachricht 4 von 7
lee_griggs
Yes, just reduce the Specular Weight. Why does roughness need to be so high? I never have it fully at 1. Its practically acting like a Lambert shader.
Lee Griggs
AUTODESK
Nachricht 5 von 7
lee_griggs
You could also reduce Indirect Specular if that is also an issue as well as Clamping and Indirect Specular Blur.
Lee Griggs
AUTODESK
Nachricht 6 von 7
Joseph_Kim
I put roughness value to one hoping that it would reduce the intensity of the reflected light. What do you think about playing with IOR values?
Thanks!!
Nachricht 7 von 7
lee_griggs
Could do, but that is more likely to affect the Fresnel edge.
Lee Griggs
AUTODESK
