Arnold General Rendering Forum
SetParameter Standin Subdiv override
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Andrew_Wilkins1
356 Aufrufe, 2 Antworten
In quick testing on a basic sphere standin, I can't seem to be able to change subdiv type or iterations with a standin shape node operator override. (aiSetParameter)
subdiv_type=1
subdiv_iterations=4
Those were the default parameters when creating the override from the drop-down list, but is it actually something different?
Or are subdiv settings currently not able to be modified via an operator on standins?
Thank you. :]
2 ANTWORTEN 2
Nachricht 2 von 3
Stephen.Blair
als Antwort auf: Andrew_Wilkins1
subdiv_type="catclark"
because otherwise you get this the script history:
setAttr -type "string" aiSetParameter1.assignment[0] "subdiv_type=1";
// Warning: [parameter] enum parameter "subdiv_type" is neither a literal string or a valid reference: 1 //
// Warning: [assignment] unable to process parameter "subdiv_type": subdiv_type=1 //
and in the Arnold log:
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 3
Andrew_Wilkins1
als Antwort auf: Stephen.Blair
Okay right! Thanks so much once again. :leicht_lächelndes_Gesicht:
