I'm wondering what the "required aovs" in a raw driver actually does.
I usually fill it in like a good citizen of the arnold universe:
static const char *required_aovs[] = {"RGBA RGBA", "VECTOR P", "FLOAT Z", "RGBA transmission", NULL}; AiRawDriverInitialize(node, required_aovs, false);However, it doesn't make a difference if I remove the required aovs. So I was wondering what the purpose of this is. The API docs simply say:
NULL-terminated array of AOV descriptors ("TYPE name") to route to this driver
Thanks lads
Z
You can remove the required AOVs and still access them?
And they are not output by for any other driver?
Yes, I can remove them and still access them. They are output by another driver currently (both exr_driver and a custom one).
However, I cannot access the AOVs if linked to the exr_driver only (regardless of specification in the required_aovs)
