Arnold General Rendering Forum
"Eleven" Rig eyes not rendering
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
3047 Aufrufe, 5 Antworten
Hey hopefully quick texturing/lighting question. I'm using the "Eleven" rig and I've gotten him to light relatively well using the Arnold renderer, however I can not get his eyes to light properly while inside his head. If I move the eyes outside of the skull, they light, however while inside the skull it appears as matte black. I've tried reattaching textures, putting lights closer to the eyes, and creating an entirely new texture to it. If anyone has any insight, please let me know. Thanks!
(they also work if i pull them a little out)
Links to the rig:
Direct download: https://dl.dropbox.com/s/p9z3pxbff8thpbo/ElevenRig_v1.2.zip
Rig Website: http://elevenrig.blogspot.com
Tags (3)
Beschriftungen (3)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
SOLUTION: Go into the hypershade and find the transparent material (eyeshader_transparancy blinn). Right click and select objects assigned to that material and just delete.
Nachricht 3 von 6
Nachricht 4 von 6
lee_griggs
JFYI, there is also an Arnold > Utility that converts old Maya Blinn shaders to Arnold Standard Surface shaders.
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 5 von 6
pkavanaugh
@Kaitlyn Monsivais
I don't understand your answer. Delete the geometry for the eyes? Or delete the blinn shader?
Nachricht 6 von 6
lee_griggs
als Antwort auf: pkavanaugh
I'm guessing they meant to delete the geometry around the eyes that are causing the issue.
Lee Griggs
AUTODESK
