1.Wet hair effect with standard hair shader?
2. Does Arnold bump2d node convert maps to normal maps?
3.Is the scatter input in arnold only useful for viscous liquids,can it be used for milk or orange juice/intead of sss
Gelöst! Gehe zur Lösung
Gelöst von lee_griggs. Gehe zur Lösung
1. From the docs: "You can use IOR values outside of 1.4-1.6 to render wet hair."
2. https://docs.arnoldrenderer.com/display/A5NodeRef/bump2d#bump2d-normal
3. From the docs: "Transmission Scatter is suitable for any liquid that is fairly thick or where there is enough of it for scattering to be visible, such as a deep body of water or honey."
In the future can you name your question better to help other users of Arnold Answers, please? Could you also choose which plugin you are using? Could you also read the docs first so that we don't have to search it for you?
