Arnold General Rendering Forum
Padding vs Volume Padding in Volume node?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
excentriPMNA2
727 Aufrufe, 3 Antworten
what is the difference between "Padding" attribute and "Volume Padding" attribute in Volume node?
i'm sorry. i understand volume padding attribute now.
but, what is the role of "Padding" attribute in Volume node?
3 ANTWORTEN 3
Nachricht 2 von 4
ben.fischler
als Antwort auf: excentriPMNA2
Which Arnold plugin are you using? Houdini? Maya? And which version?
Nachricht 3 von 4
Stephen.Blair
Padding is a UI mistake that will be fixed.
Volume Padding is what you want to use, and it is described in the docs.
// Stephen Blair
// Arnold Renderer Support
Nachricht 4 von 4
excentriPMNA2
thank you for your reply.
