Arnold General Rendering Forum
Override USD curve basis in StandIn?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
BrianHanke
444 Aufrufe, 2 Antworten
Hi all, is it possible to override the basis of USD curves in a StandIn? I tried importing this groom as Alembic and you can use the Alembic Settings > Curve Basis dropdown to change it no problem. However, when opening the same groom via USD then the Alembic section has no effect. If I try to create a local override for basis I get an error:
2 ANTWORTEN 2
Nachricht 2 von 3
BrianHanke
als Antwort auf: BrianHanke
Bump. Still curious if there's a solution to this.
Nachricht 3 von 3
Stephen.Blair
The alembic procedural re-samples the curve if you change the basis.
The other procedurals do not do that.
// Stephen Blair
// Arnold Renderer Support
