Arnold General Rendering Forum
Operators to query shape name
6 ANTWORTEN 6
Nachricht 1 von 7
juls_
679 Aufrufe, 6 Antworten
Currently I'm trying to solve the following situation:
We have some assets coming from speedtree for an environment. At the moment each of the individual shapes for all of those assets have corresponding textures with the same name. Say we have a poly shape called G_leaves_Shape we have a corresponding texture called leaves.tx.
The way we are assigning those textures currently is through userdata. We set a string userdata by stripping the G_ prefix and _Shape suffix on all shapes (they're always the same) and set the remainder (leaves) as a userdata attribute which we are then referencing in our aiImage nodes. This is however not baked in the source alembics, but rather happens in the render DCC (in this case Katana).
Now, we wanted to make use of the alembic procedural which makes time-to-first-pixel a lot faster and uses less memory. As we however do not have the needed userdata baked on the alembics I was wondering if there's any way to set the basename of a mesh node via regex with operators. name always gives me the full path (eg /root/world/geo/tree1/G_leaves/G_leaves_Shape), but I only need the basename (eg G_leaves_Shape).
From what I can tell I can strip the pre- and suffix from the name of each node with a string_replace operator already. Now I'd only need to set an arbitrary attribute referencing the shape name. Is this possible?
Also as a side question: Is there a straight forward way to bake the effect of operators to inspect the results they have in an ass file for debugging purposes?
Julius
Beschriftungen (4)
6 ANTWORTEN 6
Nachricht 2 von 7
Stephen.Blair
als Antwort auf: juls_
Set Parameter can set user data.
Sorry, no. That would be great, and we do have an enhancement ticket logged for that
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 7
juls_
Sorry, I think I should be more specific. I would like to set dynamic userdata with the set_parameter operator. Instead of setting the same value on all shapes in the scene, I would like to set the shape name as a userdata attribute. Is this possible?
That's good to know, thanks for the info!
Nachricht 4 von 7
Stephen.Blair
If you are changing the shape name, then you could assign that parameter value to the user data.
Like in example 2 here: https://answers.arnoldrenderer.com/answers/27210/view.html
 selection "*.(@node=='polymesh')"
 assignment "string tex=name"
// Stephen Blair
Nachricht 5 von 7
juls_
  1. selection "*.(@node=='polymesh')"
  2.  assignment "string tex=name"
This is great, but I was wondering if there's any way to set the basename of a mesh node via regex with operators. name always gives me the full path (eg /root/world/geo/tree1/G_leaves/G_leaves_Shape), but I only need the basename (eg G_leaves_Shape).
Nachricht 6 von 7
Stephen.Blair
@ To set the name? No, you'd have to use string_replace for that.
You can use regex to selection, but not for assignment.
// Stephen Blair
Nachricht 7 von 7
juls_
@ To set the name? No, you'd have to use string_replace for that. You can use regex to selection, but not for assignment.
That's mainly what I wanted to know, thank you!
