Arnold General Rendering Forum
Opacity (transmission) MtoA
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
398 Aufrufe, 4 Antworten
Just asking if this is correct. The output works fine.
I plug in a greyscale map to Transmission Weight where black is transparent and white is opaque. The transmission color is the base color map.
4 ANTWORTEN 4
Nachricht 2 von 5
lee_griggs
als Antwort auf: Anonymous
I would try Opacity here.
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 3 von 5
@Lee Griggs
thank you. The issue I have with opacity is that I can't get the colour of the transparency to show. So if I put the color into the transmission color I get that colour shining through but with opacity it seems to be transparent or opaque
Nachricht 4 von 5
lee_griggs
ok great. So everything is working as you expected then?
Lee Griggs
AUTODESK
Nachricht 5 von 5
@Lee Griggs
Thank you for the reply.
Yes I made up a new example (attached if interested) and for whatever reason its working fine.
(opaque off added to let the light shine through)
thanks again
simpleplane.zip
