Arnold General Rendering Forum
Noice won’t process full sequence
2 ANTWORTEN 2
Nachricht 1 von 3
ep
458 Aufrufe, 2 Antworten
Hi there,
I´m having an issue with Noice (MAC version), in which it doesn’t recognize the frame sequence and stops at a certain point saying it is “Unable to load file”
I’m using a frame padding of 4 and it just seems that Noice can´t go beyond frame 0009 since at that point it starts looking for frame 10 (instead of 0010).
Here´s a copy of my log showing where this happens:
noice 5.1.1.0 [e338d869] - the Arnold denoiserLoading images...Loading file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0008.exr".Using feature AOV 'diffuse_albedo'Using feature AOV 'N'Using feature AOV 'Z'Working with 1 frame.Will denoise AOV "RGBA"Start denoising (patch radius 3, search radius 6, variance 3)Denoising RGBAFinished denoisingSaving image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0008_denoised.exr (1280 x 720 x 4)
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009.exr
------------------------ (9/122)
Loading images...
Loading file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009.exr".
Denoising RGBA
Finished denoising
Saving image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009_denoised.exr (1280 x 720 x 4)
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10.exr
------------------------ (10/122)
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11.exr
------------------------ (11/122)
Loading images...
Unable to load file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10.exr".
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_12.exr
------------------------ (12/122)
Loading images...
Unable to load file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11.exr".
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_13.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_13_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_13.exr
------------------------ (13/122)
2 ANTWORTEN 2
Nachricht 2 von 3
Stephen.Blair
als Antwort auf: ep
It works fine on macOS with the MtoA 3.2.0.2. I didn't try an older versions (you're using MtoA 3.0.1.0)
Are there any other files in that folder, along with the ones you want to denoise?
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 3
ep
als Antwort auf: ep
Hi Stephen,
Nope. The only files in that folder are the animation sequence that came straight out of Maya.
Guess I'll have to upgrade to the latest version.
Thanks for the help.
