Arnold General Rendering Forum
Noice Deadline plugin
4 ANTWORTEN 4
Nachricht 1 von 5
tgdadmin
1066 Aufrufe, 4 Antworten
Ten Gun Design would like to share the release of our Noice plugin for the Deadline render manager:
https://github.com/TenGunDesign/Noice-Deadline
For those using Deadline, we hope that this will help make denoising an easier choice in your pipeline. Denoising can be a significant processing task to run on artist machines, and distributing this work has made it possible to enjoy the use of this tool in production.
If this is not the preferred forum for sharing this kind of news, please let us know where a post like this might better serve the community. Thank you.
Tags (1)
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: tgdadmin
Thanks for sharing the plugin. However, I can't get it to work properly. The job will submit successfully but the output file is continually overwritten with the frame number selected in the input pattern. The frame list is populated correctly with the frame range.
Analyzing the render node log I can see that the command is using the input frame properly but continually setting the output to the first frame seletected in the input pattern.
Dealine 10.0.25.2
Nachricht 3 von 5
Analyzing the render node log I can see that the command is using the input frame properly but continually setting the output to the first frame selected in the input pattern.
Dealine 10.0.25.2
Nachricht 4 von 5
I admit that this has been very messy.
However, existing scripts have too much inconvenience to be entered manually.
I fixed some things.
However, I make it automatically folder when I press OK,
but I am not a programmer.
I would like to add a phrase to automatically create a folder in the deadline.
NoiceSubmission.zip
Nachricht 5 von 5
Max_Steven
Hello I put the files into custom folder but it not show up in Deadline Submit menu with Deadline v10
