Multiple outputs
Multiple outputs
maxtarpini
Multiple outputs
maxtarpini
I see that both Maya and Houdini for Arnold does not obey the Arnold spec around shader multiple outputs.
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_user_guide_ac_release_notes_ac_rn_7000_html
Ie. let's say I have three outputs : color, distance and bump.
'color' being the default is indexed as -1 and should not be listed in node_parameters and so it should just appear in the output list in Maya or Houdini.. but it does not. I have to explicitely list it in node_parameters and also index it. Eventually I copy the same output also for -1 to support default.
This is not happening in C4DTOA (new editor) for example where the specification is followed correctly.
In code this should be something like this :
    case SVoronoiOutput::COLOR:     // -1 .. default output
        sg->out.RGB() = AtRGB(Output.Color.x, Output.Color.y, Output.Color.z);
        break;
    case SVoronoiOutput::DISTANCE:  // 0 .. first multiple output
        sg->out.RGB() = AtRGB(Output.Distance);
        break;
    case SVoronoiOutput::BUMP:      // 1 .. second multiple output
        sg->out.FLT() = (Output.Position.x + Output.Position.y + Output.Position.z) /3.f;
        break;
instead to be able to see 'color' output I have to ..
    case -1:                        // -1 .. default output
        break;
    case SVoronoiOutput::COLOR:     // 0 .. color output
        break;
    case SVoronoiOutput::DISTANCE:  // 1 .. second multiple output
        break;
    case SVoronoiOutput::BUMP:      // 2 .. third multiple output
        break;
It's not a problem at all because the last code block works cool also for C4DTOA. Maybe some minor cosmetic thing where DCC apz won't have the their usual default name for their default outputs. My main worries is if you plan to keep this thing consistent or not .. meaning if you're aware of this and won't change it later.
Potentially, the bug is : with multiple outputs we have to explicitely add and index a default output too or it won't be exposed in the UI while this is not part of the original multiple output specification.
Makes sense, what do you think ?
Btw, it looks super nice and useful.
maxtarpini
This is now broken in c4dtoa 4.8.6 (Arnold 7.4.5.0).
It always outputs the default output.
Just follow the guide here :
node_parameters
   AiOutputRGB("green"); // first output is indexed as 0
   AiOutputFlt("pi"); // second output is indexed as 1
case 0: sg->out.RGB() = AI_RGB_GREEN; return;
case 1: sg->out.FLT() = AI_PI; return;
case -1: sg->out.RGB() = AI_RGB_BLUE; return;
It will always output a blue color regarding of what output we choose.
 @peter_howard
peter_horvath
Hey Max, It is indeed broken when connected directly to the Arnold Material end node. It is working fine when connected to other nodes. For instance in your example if you add a flat shader in between. I'll take a look and fix it in our next release. Thank you.
// Peter Horvath
// C4DtoA developer
peter_horvath
This is actually not a regression, but a limitation. Arnold does not support custom outputs connected directly to shapes. It does not work in Maya either. You need to use an intermediate node as a workaround. The plugin could be smarter though and do this for you under the hood.
// Peter Horvath
// C4DtoA developer
maxtarpini
All cool .. effectively on Maya I was using a color to closure node.
Thanks for the feedback ! 🖖
