Arnold General Rendering Forum
Mode in the mix shader?
2 ANTWORTEN 2
Nachricht 1 von 3
excentriPMNA2
215 Aufrufe, 2 Antworten
The following description in Arnold manual is written. (
https://support.solidangle.com/display/A5AFMUG/Mix+Shader )
"The Add mode is used for adding two shaders that only emit light."
I don't know "shader that only emit light".
What shader is that shader?
2 ANTWORTEN 2
Nachricht 2 von 3
maxtarpini
als Antwort auf: excentriPMNA2
Well if you don't know them .. you may not really need them :leicht_lächelndes_Gesicht: ... btw aiblackbody and any flat color shader when not attached as texture to a material slot ... may be seen as an emitter.
Nachricht 3 von 3
excentriPMNA2
als Antwort auf: maxtarpini
thank you for your reply
