when im rendering animation file, after some frames render frames are not completing and skip to new frame,( my files are rendering through network)
Some frames are rendering are fine but some are getting error,any suggestion ? @Lee Griggs
Sounds like a network issue. Does it render fine locally?
I think this is not a network issue, if this is a network issue then same time another file is giving same render output without any glitch.
May be system heating issue, which is not supported on that time.
Had same issue. Images are rendered completely but occasionally few frames will show blank lines as if they where not rendered. Not sure where to look for this. If any one find please post it. I'll keep an eye on this post.
Unless it's an incredibly simple scene, most of the time Arnold will not be writing to disk, so if there's a temporary hiccup in the network, during that fraction of a second that the network has an issue, it's entirely possible the 100 other render nodes might not be actively writing pixels to disk and so won't have any issues.
Having said that, it's not clear yet to me this is a network issue, though at the moment that does seem like the best guess.
What file format are you writing to (png, exr, tif, etc.)? What happens if you switch between scanline to tiled output for tiff/exr files? Are there any log errors when this problem happens? Maybe using one of the other file formats will cause an error message to be output?
Tried on .tif and .exr. render is going on smoothly without any issue it's just when I check each frame some random frame have issue.
