Arnold General Rendering Forum
MaxToA 3.2.65 And Arnold Normal Map Material
2 ANTWORTEN 2
Nachricht 1 von 3
derek.mallard
391 Aufrufe, 2 Antworten
I'm still having a rough situation where I'm seeing very black edges around my models using the Arnold Normal Map material. I've figured most of it out and it's not the normal map textures itself causing the issue, it's whatever version of MaxtoA that fixed the normal map textures not rendering properly. I've explained in my last thread and I don't know if anyone acknowledged it.
Here I have a plane and a sphere. The sphere is using the Arnold Normal map material and I've used a bright pane to expose the dark edges. (In other cases you can still see it regardless. Also I've tried a lot of other normal textures but it's not the issue as I said.)
The sphere has 13 segments here.
And here it is with 100 segments and still using the normal material.
I can use a turbosmooth on my models with a value of 3 or 4 but, that's gonna rip holes in them and it will hardly ever fix the issue. So I guess in my case, I can't use any normal materials without having to see those dark edges.
I was already asked if I changed any values within the normal materials and gamma values, and it doesn't help.
- I have a Windows 10 and I'm using 3DS Max 2020.
Will I not be able to use normals?
Beschriftungen (5)
2 ANTWORTEN 2
Nachricht 2 von 3
madsd
als Antwort auf: derek.mallard
You are doing something fundamentally wrong in the process if you can semi fix it with a higher density model.
We need to find out where in a correct workflow you start to divert.
Nachricht 3 von 3
derek.mallard
@Mads Drøschler
This post took 3 days for it to be viewed by a moderator, over those days, I've found out something while looking at one of the character models. I was playing with the edges in editable poly mode and I've stretched one the edges upward and I can see the black edge as clear as a bright and sunny day. (it got thicker the more I stretched it)
Basically I always use physical material and I just select the "Arnold Normal Map" material in the node where it says "Bump Map". I then select the normal texture and I use them in "Input" and "Tangent", that's it.
