yes i have both a maya and a arnold subscription (one of each) that I use on my linux machine (centos 7.8)
Christoph, yes, i'm sure i can read batch render correctly 🙂
here is the result of licence diagnostic :
License diagnostics executed at 2021-05-28 15:48:43
Single-user Licensing Version: 11.0.0.4854
kick -nostdin -v 1 -i /dev/null (1.57 sec)
00:00:00 73MB | log started Fri May 28 15:48:43 2021
00:00:00 73MB | Arnold 6.1.0.1 [07981301] linux clang-10.0.1 oiio-2.2.1 osl-1.11.6 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.6.0 2020/12/15 09:25:16
00:00:00 73MB | running on hawkins, pid=147414
00:00:00 74MB | 2 x Intel(R) Xeon(R) Gold 6138 CPU @ 2.00GHz (40 cores, 80 logical) with 385598MB
00:00:00 74MB | NVIDIA driver version 460.73 (Optix 60800)
00:00:00 74MB | GPU 0: GeForce RTX 2080 Ti @ 1545MHz (compute 7.5) with 11019MB (9543MB available) (NVLink:0)
00:00:00 74MB | GPU 1: GeForce RTX 2080 Ti @ 1545MHz (compute 7.5) with 11019MB (11008MB available) (NVLink:0)
00:00:00 74MB | GPU 2: GeForce RTX 2080 Ti @ 1545MHz (compute 7.5) with 11019MB (11009MB available) (NVLink:0)
00:00:00 74MB | GPU 3: GeForce RTX 2080 Ti @ 1545MHz (compute 7.5) with 11019MB (11009MB available) (NVLink:0)
00:00:00 74MB | GPU 4: GeForce RTX 2080 Ti @ 1545MHz (compute 7.5) with 11019MB (11009MB available) (NVLink:0)
00:00:00 74MB | GPU 5: GeForce RTX 2080 Ti @ 1545MHz (compute 7.5) with 11019MB (10729MB available) (NVLink:0)
00:00:00 74MB | GPU 6: GeForce RTX 2080 Ti @ 1545MHz (compute 7.5) with 11019MB (11009MB available) (NVLink:0)
00:00:00 74MB | GPU 7: GeForce RTX 2080 Ti @ 1545MHz (compute 7.5) with 11019MB (11009MB available) (NVLink:0)
00:00:00 74MB | CentOS Linux 7 (Core), Linux kernel 3.10.0-1160.6.1.el7.x86_64
00:00:00 74MB | soft limit for open files is set at 63534
00:00:00 74MB |
00:00:00 74MB | loading plugins from /mnt/Pipeline/Arnold ...
00:00:00 74MB | no plugins loaded
00:00:00 74MB | loading plugins from /opt/Arnold/bin/../plugins ...
00:00:00 74MB | loaded 5 plugins from 3 lib(s) in 0:00.00
00:00:00 74MB | [kick] command: /opt/Arnold/bin/kick -nostdin -v 1 -i /dev/null
00:00:00 74MB | loading plugins from . ...
00:00:00 76MB | no plugins loaded
00:00:00 76MB | [ass] loading /dev/null ...
00:00:00 76MB | [ass] read 0 bytes, 0 nodes in 0:00.00
00:00:00 77MB |
00:00:00 77MB | authorizing with license manager: user ...
00:00:01 78MB | [user] authorized user "dothefilm" in 0:01.09
00:00:01 78MB | [user] expiration date: unknown
00:00:01 78MB |
00:00:01 78MB |
00:00:01 78MB | releasing resources
00:00:01 78MB | Arnold shutdown
kick -licensecheck (0.51 sec)
RLM DEBUG for product "arnold"
0 product instances found
Could not find any license files, please check the license server, the license may be expired
Please contact licensing@solidangle.com
environment:
solidangle_LICENSE = (null)
RLM_LICENSE = (null)
lmutil lmstat -S adskflex -a -f 87287ARNOL_2020_0F (0.01 sec)
lmutil - Copyright (c) 1989-2018 Flexera. All Rights Reserved.
Flexible License Manager status on Fri 5/28/2021 15:48
Error getting status: Cannot find license file. (-1,359:2 "No such file or directory")
rlmutil rlmhostid -q ether (0.01 sec)
ac1f6ba45eb8 ac1f6ba45eb9 ac1f6bacbe5c ac1f6bacbe5d 52540082c085
FlexLM environment (0.00 sec)
ADSKFLEX_LICENSE_FILE (local env) =
ADSKFLEX_LICENSE_FILE (global user env) =
Adlm FlexNET cache =
Adlm FlexNET cache location = /home/william/.flexlmrc
here is the licensing error :
2021-05-28 15:54:17: 0: STDOUT: 00:00:00 657MB | authorizing with license manager: user ...
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB WARNING | rendering with watermarks because of failed authorization:
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB | [clm.v2] timeout before callback was called
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB | environment variables:
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB | ARNOLD_LICENSE_ORDER = (not set)
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB | ARNOLD_LICENSE_MANAGER = (not set)
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB | [rlm] solidangle_LICENSE = (not set)
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB | [rlm] RLM_LICENSE = (not set)
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB | [clm] ADSKFLEX_LICENSE_FILE = (not set)
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB | [clm] LM_LICENSE_FILE = (not set)
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB ERROR | aborting render because the abort_on_license_fail option was enabled
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB | releasing resources
2021-05-28 15:54:27: 0: STDOUT: 00:00:10 658MB | Arnold shutdown
