Arnold General Rendering Forum
Lee Griggs' Refractive Portrait's Tutorial - Camera/Projection Node Connection
10 ANTWORTEN 10
Nachricht 1 von 11
823 Aufrufe, 10 Antworten
Hey Everyone,
I was trying to follow Lee Griggs' Tutorial "Refractive Portraits"...However, I'm having a problem with the graph nodes...I don't understand with attribute/parameter he uses to connect te "RenderCam" node to the projection node.
Lee Graph: graphnodelee.png
My Graph: graphnodemine.png
Thank you in advance!
Tags (1)
Beschriftungen (1)
10 ANTWORTEN 10
Nachricht 2 von 11
lee_griggs
als Antwort auf: Anonymous
That is automatically done in Maya when you project a file texture. That is an Arnold 4 tutorial btw. It may not work properly with Arnold 5, in case that is what you are using.
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 3 von 11
It is automatically done when i create which node exactly?
Because what I do is go to the alshader for example on the diffuse color...and instead of clicking "file" with the left mouse button I use the right mouse button "create as projection"...and the render node is created when I create the camera , but it doesnt connect to the node...so I dont get what I'm doing wrong
Nachricht 4 von 11
lee_griggs
We don't support alsurface shaders now I am afraid. If you use Standard Surface in Arnold 5 I can help you.
Lee Griggs
AUTODESK
Nachricht 5 von 11
lee_griggs
You need to change the projection type to 'perspective' and then choose the Rendercam underneath.
Lee Griggs
AUTODESK
Nachricht 6 von 11
Oh, Okay let's say I use a standard surface in Arnold 5...How do I know which attributes correspond to the alshader?
Nachricht 7 von 11
lee_griggs
Test Transmission, IOR etc. Experiment and play around to see what works. Let me know if you come up with something that works.
Lee Griggs
AUTODESK
Nachricht 8 von 11
@Lee Griggs
Hey, I downloaded Maya 2017 since it contains arnold 4 and installed the alshaders...And then I did the tutorial from start to end. However, It doesn't really seem to work, this is how it looks at the moment when I render:help.png
and this is my hypershade:help02.png
This is the scene if you would like to give a quick look(20MB):https://we.tl/t-3VFUlm5s72
Nachricht 9 von 11
lee_griggs
Sorry, I can't help you with alsurface or Arnold 4. Did you try it with Standard Surface in Arnold 5?
Lee Griggs
AUTODESK
Nachricht 10 von 11
@Lee Griggs No, I guess it's possible to do it...but I don't know which values to use for the attributes and to which attributes connect the projection shader, as I guess the name of the attributes will be different being a different shader.
Nachricht 11 von 11
lee_griggs
It may be difficult to reproduce, but worth a try. Try experimenting with adding the texture to IOR, Transmission and just see what happens. That is how I came up with it in the first place, by just experimenting.
Lee Griggs
AUTODESK
