Arnold General Rendering Forum
Issue With Arnold Rendering
2 ANTWORTEN 2
Nachricht 1 von 3
gbouletAZ23M
311 Aufrufe, 2 Antworten
My name is Gabriel Bouelt Emery, and it seems that I'm experiencing difficulties in rendering images with Arnold. The module appears to be installed correctly, and I have checked my rendering settings multiple times, and everything seems to be functioning properly. However, the issue is that no images are being generated in the project's image folder. Maya indicates that the renders are successful and complete, but no images are being generated regardless of the format. I want to specify that I have a teacher's license for a course at the college (Cegep). The technicians at the college are also experiencing the same problem on their end. However, my students seem to have no issues; I have tested it with them, and they are able to successfully generate rendered images with Arnold in their project folders. Can anyone help me with this issue? I have tried reinstalling Maya and Arnold and reactivating my license, but Autodesk indicates that I need to contact my administrator. However, the Cegep technicians are getting the same message.
Here is my adresse if you want to contact me :
gboulet@cegeptheford.ca
thanks a lot!
Gabriel Boulet Emery
2 ANTWORTEN 2
Nachricht 2 von 3
Stephen.Blair
als Antwort auf: gbouletAZ23M
No images when you batch render? Can you post an Info-level Arnold log for a batch render?
The log verbosity is in Render Settings > Diagnostics.
By default, the log will go into your MayaRenderLog, in your home folder.
License will have nothing to do with this.
"Autodesk indicates that I need to contact my administrator" > I don't know what this is, when does this happen? Sounds like single-user licensing and seat assignment.
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 3
gbouletAZ23M
als Antwort auf: Stephen.Blair
hello,
Here is my script editor when i launch my batch render with Anrold :
file -f -new;
// untitled
doOpenFile ("C:/Users/gboulet/OneDrive - Cégep de Thetford/Bureau/Teste rendu/Teste Rendu.mb");
file -f -options "v=0;" -ignoreVersion -typ "mayaBinary" -o "C:/Users/gboulet/OneDrive - Cégep de Thetford/Bureau/Teste rendu/Teste Rendu.mb";addRecentFile("C:/Users/gboulet/OneDrive - Cégep de Thetford/Bureau/Teste rendu/Teste Rendu.mb", "mayaBinary");
requires "stereoCamera" "10.0";
updateRenderOverride;
requires -nodeType "aiOptions" -nodeType "aiAOV" -nodeType "aiAOVDriver" -nodeType "aiAOVFilter" -nodeType "aiAxfShader" -nodeType "aiLambert" "mtoa" "5.2.1.1";
evalDeferred "shaderBallRendererMenuUpdate";
// Warning: file: C:\Users\gboulet\OneDrive - Cégep de Thetford\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\gboulet\OneDrive - Cégep de Thetford\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\gboulet\OneDrive - Cégep de Thetford\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'.
// Warning: line 1: filePathEditor: Attribute 'aiVolume.filename' and label 'VDB' have been saved already.
// Warning: line 1: filePathEditor: Attribute 'aiImage.filename' and label 'Image' have been saved already.
// Warning: line 1: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' and label 'IES' have been saved already.
import arnold
import mtoa
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
import mtoa.viewport;mtoa.viewport.add_controls()
// Warning: line 1251: The default image may not be modified. Use the -i/image flag instead.
// File read in 3.3 seconds.
commandPort -securityWarning -name commandportDefault;
// Error: line 1: Could not open command port b'commandportDefault' because that name is in use.
onSetCurrentLayout "General";
updateRendererUI;
// AbcBullet v1.0 using Alembic 1.8.3 (built Nov 2 2022 10:53:22)
# # C:\Program Files\Autodesk\MayaUSD\Maya2023\0.20.0\mayausd\USD\lib\python\pxr\UsdUtils\updateSchemaWithSdrNode.py:372: SyntaxWarning: "is not" with a literal. Did you mean "!="?
if sdrIdentifier is not "":
// Bifrost: Pre-loaded mayaUsdPlugin to access proper Maya USD libraries.
// Loading Bifrost version 2.5.1.0-202208011913-c060626
// Bifrost: Loading library: Amino, from: Autodesk.
// Bifrost: Loading library: AminoMayaTranslation, from: Autodesk.
// Bifrost: Loading library: bif, from: Autodesk.
// Bifrost: Loading library: bifrostObjectMayaTranslations, from: Autodesk.
// Bifrost: Loading library: geometries, from: Autodesk.
// Bifrost: Loading library: fluids, from: Autodesk.
// Bifrost: Loading library: particles, from: Autodesk.
// Bifrost: Loading library: file, from: Autodesk.
// Bifrost: Loading library: mpm, from: Autodesk.
// Bifrost: Loading library: modeling, from: Autodesk.
// Bifrost: Loading library: nucleus, from: Autodesk.
// Bifrost: Loading library: simulation, from: Autodesk.
// Bifrost: Loading library: riv_types, from: Autodesk.
// Bifrost: Loading library: riv, from: Autodesk.
// Bifrost: Loading library: scatter_pack, from: Autodesk.
// Bifrost: Loading library: graphs, from: Autodesk.
// Bifrost: Loading library: usd_pack, from: Autodesk.
// Bifrost: Loading library: usdMayaTranslations, from: Autodesk.
// cgfxShader 4.5 for Maya 202303.0 (Nov 2 2022)
// AbcExport v1.0 using Alembic 1.8.3 (built Nov 2 2022 10:53:22)
// AbcImport v1.0 using Alembic 1.8.3 (built Nov 2 2022 10:53:22)
updateRendererUI;
+++++++ Turtle for Maya registered successfully ++++++
updateRendererUI;
// Saving temporary file: C:/Users/gboulet/OneDrive - Cégep de Thetford/Bureau/Teste anim/Teste Rendu__185368.mb
// Rendering with Maya Hardware 2.0...
// Percentage of rendering done: 0 (C:/Users/gboulet/OneDrive - Cégep de Thetford/Bureau/Teste anim/images/Teste Rendu.1.png)
// Percentage of rendering done: 100 (C:/Users/gboulet/OneDrive - Cégep de Thetford/Bureau/Teste anim/images/Teste Rendu.1.png)
// Saving script editor tabs to: C:/Users/gboulet/OneDrive - Cégep de Thetford/Documents/maya/2023/prefs/scriptEditorTemp
addOneTabToGlobalsWindow("arnold", "Common", "createArnoldRendererCommonGlobalsTab");
addOneTabToGlobalsWindow("arnold", "Arnold Renderer", "createArnoldRendererGlobalsTab");
addOneTabToGlobalsWindow("arnold", "System", "createArnoldRendererSystemTab");
addOneTabToGlobalsWindow("arnold", "AOVs", "createArnoldAOVTab");
addOneTabToGlobalsWindow("arnold", "Diagnostics", "createArnoldRendererDiagnosticsTab");
// Result: Render Cancelled.
// Result: Saving temporary file: C:/Users/gboulet/OneDrive - Cégep de Thetford/Bureau/Teste anim/Teste Rendu__185368.mb
// Result: Rendering with Arnold Renderer...
// Result: Percentage of rendering done: 0 (C:/Users/gboulet/OneDrive - Cégep de Thetford/Bureau/Teste anim/images/beauty/Teste Rendu.1.jpg)
// Result: Percentage of rendering done: 100 (C:/Users/gboulet/OneDrive - Cégep de Thetford/Bureau/Teste anim/images/beauty/Teste Rendu.1.jpg)
// Result: Rendering Completed. See mayaRenderLog.txt for information.
Additionally, there is this window (see photo) that appears when I launch my batch render.
