Arnold General Rendering Forum
Is it possible to override procedurals using Python?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Shawn_Kearney1
482 Aufrufe, 3 Antworten
Currently I am using a Python tag to read a C4D User Data container item, and pass that to a predefined override to control things like a specific node's render visibility or a light's intensity. Is there some way to set up overrides directly in the python tag without having to first specify it in the 'overrides' tab of the procedural?
Tags (2)
Beschriftungen (2)
3 ANTWORTEN 3
Nachricht 2 von 4
You mean the new 5.1 parameter override in the Arnold Procedural? You should be able to setup that from a python script. I'll show you an example later, if that's what you're looking for.
Nachricht 3 von 4
yes, the parameter override, sorry for being vague. I look forward to your example!
Nachricht 4 von 4
Added the description to the documentation:
https://support.solidangle.com/display/A5AFCUG/Arnold+Procedural+Parameter+Overrides
There's a full script at the bottom of the page which you can download.
