Is there a way to interrogate an existing .tx file? Pixar have the little 'txinfo' utility with Renderman that will list the metadata, similar to the verbose output when you run maketx from the command line. Always found it handy.
Gelöst! Gehe zur Lösung
Gelöst von Stephen.Blair. Gehe zur Lösung
you can use oiiotool -v --info
the htoa install includes oiiotool
